Setting up NTP in XOS
  • 2
  • Question
  • Updated 3 years ago
  • Answered
Does any one know the syntax to set up an NTP server  to point to 172.16.20.1 in XOS
Photo of shakil khan
shakil khan
  • 280 Points 250 badge 2x thumb
Posted 4 years ago
  • 2
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
• To configure an NTP server, use the following command:configure ntp [server | peer] add [ip_address | host_name] {key keyid} {option
[burst | initial-burst]}
configure ntp restrict-list [add | delete] network {mask} [permit | deny]
• To delete an NTP server, use the following command:
configure ntp [server | peer] delete [ip_address | host_name]
• To display NTP server or client information, use the following commands:
show ntp
show ntp association [{ip_address} | {host_name}]
show ntp restrict-list {user | system | all}
show ntp sys-info
Please refer page 70in concepts guide 15.6 for more information
Based on EXOS version you might need NTP module installed
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
after installled NTP module. do we need to reboot the device? or any command to update/apply this module please? thanks.
no
Photo of Drew C.
Drew C., Community Manager
  • 38,546 Points 20k badge 2x thumb
Hi Paul, If you're not able to configure or enable NTP immediately after installing, it may be necessary to execute the run update command to refresh the installed modules.  As Parthiban indicated, you won't need to reboot.
shakil khan
whats the link to download the guide 15.6
Photo of Drew C.
  • 39,516 Points 20k badge 2x thumb
Hi Shakil,
You can find Extreme Network product documentation here:
https://www.extremenetworks.com/support/documentation
shakil khan
Hi Drew
wondering if you can help
i have a config for a port of a 3com switch that i need to convert into a port config for XOS switch x460 and i am not sure of the command syntax can you assist
interface Ethernet1/0/2
 stp edged-port enable
 broadcast-suppression pps 3000
 undo jumboframe enable
 MAC-authentication
Photo of Drew C.
  • 38,274 Points 20k badge 2x thumb
I'm creating a new thread so that we can keep new topics separated.
Please reference the new conversation here: Converting 3com port config to EXOS config
Photo of Paul
Paul
Can servers point to sync time on the Extreme switch NTP? ExtremeSwitch as a NTP server.
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
Yes. Please check EXOS User Guide v15.7, Using the Network Time Protocol (pages 70-75) for more information and configuration examples.
Photo of Paul
Paul
Thanks Daniel and Hi all,
Sorry my belated reply.
For the rest and better management on this HUB.
I just want to share config that i deploy.
I am able to implement Extreme Switch as a NTP server. PC as a NTP client.
Following is the Steps that i performed.
"Install NTP module to switch"
download image 10.49.0.200 summitX-15.3.3.5-patch1-6-ntp.xmod vr "VR-Default" primary >> Yesinstall image "summitX-15.3.3.5-patch1-6-ntp.xmod" >> Yes
run update
sh switch  - Check Clock, Timezone, XOS version and Image Booted partition
sh version image
sh ntp
sh ntp vlan
sh process ntp
"SNTP disable"
SNTP and NTP cannot run concurrently.
Copy and backup SNTP config (if you have sntp config)
unconfigure sntp-client primary/secondary x.x.x.x  vr "VR-Default"
disable sntp-client
sh sntp-client
"Configure Time on Switch"
configure time 4 27 2015 19 5 00
"Configure NTP"
sh switch - Check Current Time & Timezone again
# configure timezone name SGT 480 (for Singapore timezone GMT+8  60min x 8 = 480min)
# enable ntp
# enable ntp all   (to enable for all VLANs )
# configure ntp local-clock stratum 3
# configure ntp server add x.x.x.x
Thank you.
Photo of Daniel Valera
Daniel Valera
  • 734 Points 500 badge 2x thumb
Hi Paul, i need configure NTP in my equipments too... your post it helped me too, but i have a question: what configuration is in the SW NTP server and what lines in the SW NTP client?
Thank you....... Regards @paul
Photo of Paul
Paul
Hi Daniel,
my setup for NTP.
NTP Server is Extreme Switch.
NTP clients are Windows Servers that connect to the switch.
Daniel Valera
thanks Daniel!
i need configure one sw ntp server mode and the rests switches ntp client mode.
Regards @Paul
Daniel,
Paul's commands correspond to the switch. The configuration in the clients usually involves  configuring the IP address of the NTP server.
If you want the switch to act as a server, there's a few additional things you need to do:
1. Assign an IP address to the vlan through which the clients will contact the NTP server (configure vlan <vlan_name> add ipaddress <ip_address>/<mask>)
2. Enable the NTP broadcast server in that vlan (enable ntp vlan <vlan_name> broadcast-server {key keyid})
3. Configure the vlan to forward broadcast packets (enable ipforwarding broadcast <vlan_name>)
4. Check configuration with show ntp vlan <vlan_name>
Also, since v15.5 NTP is included in the main code and there's no need to load a separate xmod.
Daniel Valera
Hi Daniel!!!
thanks for you help. I will make a lab before. however my SW ́s have the 15.3.x EXOS so it need to load a separate xmod
Regards @Daniel
You may want to go one step forward and configure two or more switches as a peer group, for backup. Check the EXOS User Guide v16.1 page 75 (Managing NTP Peer Support) for details...
