Setting an Algorithm for MLAG?
  • Question
  • Updated 5 years ago
Create Date: Jul 17 2013 3:30PM
Bit confused about this.
I have two x670v switches running XOS 15.2.3.2 connected together via two 40Gbps Links in a LAG using a static L2 algorithm. 49 to 49 and 53 to 53 using the VIM 4 Card. I want to dual home servers via MLAG providing resilience and High bandwidth.
I've followed the XOS 15.3.2 concepts guide for setting up the ISC VLAN. All looks good, peers are talking to each other (See below). I've added port 1 on each switch to the MLAG but how do you set the algorithm? Or is it defaulted to L2 Static? I know LACP is only supported in 15.3 so am I right in thinking I don't get an option to set the algorithm because there is only L2 Static and that for LACP I need to upgrade to 15.3? See config below.
MLAG Peer                 : CTC-iSCSI-SW2
VLAN                         : ISC                         Virtual Router    : VR-Default
Local IP Address         : 1.1.1.1                     Peer IP Address   : 1.1.1.2
MLAG ports                : 1                           Tx-Interval       : 1000 ms
Checkpoint Status      : Up                          Peer Tx-Interval  : 1000 ms
Rx-Hellos                   : 2126                       Tx-Hellos         : 2177
Rx-Checkpoint Msgs    : 34                          Tx-Checkpoint Msgs: 51
Rx-Hello Errors           : 0                           Tx-Hello Errors   : 0
Hello Timeouts            : 0                           Checkpoint Errors : 0
Up Time                      : 0d:0h:34m:41s       Peer Conn.Failures: 0
MLAG Peer                 : CTC-iSCSI-SW1
Local IP Address          : 1.1.1.2                     Peer IP Address   : 1.1.1.1
Rx-Hellos                     : 2246                        Tx-Hellos         : 2246
Rx-Checkpoint Msgs       : 54                          Tx-Checkpoint Msgs: 37
Up Time                       : 0d:0h:36m:39s           Peer Conn.Failures: 0
                    Local                                                   Local   Remote
MLAG Local   Link     Remote                           Peer    Fail    Fail
Id      Port    State    Link    Peer                     Status  Count   Count
1       1       R        Down    CTC-iSCSI-SW2            Up          1       1
                    Local                                                   Local   Remote
1       1       R        Down    CTC-iSCSI-SW1            Up          1       1
(from Ian_Broadway)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jul 17 2013 3:57PM
Hmm think I've confused myself with this.
If I'm NOT using LACP at the server end (Server Teaming) then the switches don't worry about the algorithm?
So actually I'm ready to plug my server into those two ports and it will work?
However if I want to use LACP for server teaming then I'd need to upgrade my switch code?
(from Ian_Broadway)
Create Date: Aug 1 2013 10:45AM
There is bug in 15.2 with kernel panic using MLAG so better for You to upgrade switches and don't use LACP with MLAG. I had some issues with LACP and in official doc there is only static LAG. You have to only set algorithm on server side.
(from karpiu)
