Setup Mesh
Setup Mesh
Jonas_Oldfors
I try to setup Mesh between two APs. One is connected with Ethernet and one not. I found that I must setup one as Root which I try but get the following message:
configured when /wing-config/meshpoint[name='Test'] is not mapped to any interfaces
I litterly have the answer right there, but can't solve it anyway. Therefore I need help, any ideas?
Thank you!
5 REPLIES 5
Daren_Ellis
The message log you provided suggested that the meshpoint is not properly configured.
Meshpoint-device needs to be assigned to device profile or override.
and Meshpoint needs to be configured for BSS 1 on device override or profile.
If both are configured can you provide the config for both Root and Non-root?
Also please note AP model and current version of code.
hello there ,
im tring the same with 3 Aps 7532i (5.9.3) two of the are with wire and one i want to make it wireless (mesh) i config every think throught the VC ap and creat a mesh point and the cabeld AP's as root the the last one not , i give the mesh ID and enable it and set both 5 and 2,4. but it's not working ,when i check throught putty give me
#sh wire meshpoint sta
MESHPOINT TX RX TX RX TX RX
bytes bytes pkts pkts kbps kbps
Total number of meshpoint displayed: 0
can you help me please
p.s. i config every think with GUI
RobertZ
Can you provide the output of CLI commands:
' show wireless meshpoint root detail '
' show wireless meshpoint tree '
Jonas_Oldfors
Thank you for a quick reply!
I already did that. I get this error message when I add an "Device Override" for the VC to set it as Root. Or can I skip to set the VC (which has cable connected) as Root?
Thank you.
