Share does not loadshare as it should
  • Problem
  • Updated 4 years ago
Hi
Im creating a link aggregation with LACP between a X670V and a Ericsson SSR8000. The share contains 4 10Gb links and works fine except that it doesn't loadbalance over all 4 links. We have configured it to use L3-L4 as algorithm and the destinations ipaddresses contains a fair ammount of different addresses and tcp-ports. Whatever we do it just shares over 2 ports sending out from the 670. If i disable on port that actually sends traffic then it starts using all three ports but not balanced. Anyone out there with any ideas?
BR  Anders S
Photo of Anders Sjökvist
Anders Sjökvist
  • 160 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,552 Points 10k badge 2x thumb
Can you try using custom and crc, see if it improves the load balancing?
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
Check hashing and see if changing to CRC helps. Two options are xor or crc
Note: multicast traffic always takes same link.
Broadcast as well . Unknown unicast takes same link .
Anders Sjökvist
Hi and thanks for your answers.
I tried all options and i get no change still just loadsharing between 2 ports. The traffic is not multicast, only unicast with known destination.
If you disable the two links where you see traffic. Does it load share with other two active links .
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hey Anders is the traffic from the server using all 4 links?  When you do a show sharing are all of the ports on the switch active?
P
Anders Sjökvist
The incomming traffic comes on all 4 links and all ports are active. If i disable 1 of the active ports the trasffic is shared among the 3 remaining ports but not even. It looks like if i have a even amount of links the sharing is done on half of them and if i have odd number of links it shares on all links but not even.
        State   Speed  % bandwidth    % bandwidth   % bandwidth   % bandwidth
1         R       0         0.00          2.92          0.00           49.83
2         A       10000     2.03          3.01         53.13           55.13
24        R       0         0.00          3.00          0.00           37.34
25        A       10000     2.06          4.34          0.01           55.79
1         A       10000     1.48          2.92         20.33           49.83
2         A       10000     1.34          3.01         13.75           55.13
25        A       10000     1.38          4.34         21.04           55.79
1         A       10000     1.02          2.92         27.44           49.83
2         A       10000     1.03          3.01          0.01           55.13
24        A       10000     1.07          3.00         27.95           37.34
25        A       10000     1.04          4.34          0.00           55.79
* sitehub79.33 # show sharing
Load Sharing Monitor
Config    Current    Agg       Ld Share    Ld Share  Agg   Link    Link Up
Master    Master     Control   Algorithm   Group     Mbr   State   Transitions
     1      1        LACP      L3_L4       1          Y      A        1
                               L3_L4       2          Y      A        1
                               L3_L4       24         Y      A        2
                               L3_L4       25         Y      A        2
This is an expected behaviour lag algorithm doesn't do equal load balancing on all links but instead it will only load share.
Anders Sjökvist
Yes i know that we can't get perfect balance but i tink it shoud share among all links if you have a enough destination addresses/ports in the data flow. So i don't think it's expected behaviour.
Raise it to extreme TAC to get confirmation
With the results . If it is a bug they will fix it
