Sharing hosts between X450a and X460-G2
  • Question
  • Updated 2 years ago
  • Answered
We have two switches:
1. X450a
2. X460-G2
We managed to connect the two switches through a 1GE trunk. However, I am looking for a solution with higher bandwidth.
What options do you recommend?
Could I use this part for the 10G ports:
- 10304 10GBASE-CR SFP+ 1m 10GBASE-CR SFP+ pre-terminated twin-ax copper cable with link lengths of 1m.
Could I use these and do stacking:
- 16713 Summit X460-G2 VIM-2ss
- 16106 Stacking Cable, 0.5M
Thanks, Balázs
Photo of Szviatovszki Balázs
Posted 2 years ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,050 Points 10k badge 2x thumb
you'll not be able to stack them together, as x450a supports max EXOS 15.3 while x460G2 requires 15.6 min.
You can check this here:
However, you can interconnect them at 10G, if you have the 10G VIM on the x450a.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 7,974 Points 5k badge 2x thumb
you can create link aggregation of more 1G links together also = no need for VIM...
Thanks for the comments and help!
