sharing packet loss
  • Question
  • Updated 2 years ago
  • Answered
Hello Community,
I want to know if someone had the same problem.
After add a port into a sharing group there`s packet loss.
But when I disable and then enable the sharing with the new port, the problem has been solved.
What`s the explanation of that?
ExOS : 16.1.3.6-patch1-2
Photo of Julian Eble
Julian Eble
  • 1,394 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
I see this with 15.x code on 670 with MLAG and sharing and next to no traffic (1 -2 Mbps).
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,040 Points 5k badge 2x thumb
Does that port work normally?  Is it a shared medium port?
Julian Eble
Yes, it does. No, it`s a 10G port of an X460. But I`d the same problem with a X670.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,650 Points 10k badge 2x thumb
Hi Julian, Jeremy.
Can you please provide more details on this behavior?
platform, port numbers, #ports in LAG, configuration, traffic details, etc.
Julian Eble
Well the traffic is a MPLS trunk, just /30 configuration.
But the same behavior happened with a VPLS end ports.
Platform summit, with both switches being X460.
Ports are 29 and 31 left side, and righ side 31,32.
The better way to prove what I`m trying to show is a simulation lab.
Just add a new port to a sharing and see the packet loss.
With the command:
configure sharing add ports #sharingmaster add ports #portmember
(Edited)
Photo of Drew C.
Drew C., Community Manager
  • 40,238 Points 20k badge 2x thumb
Hi Julian, have you been able to get this problem sorted out?
