sharing port is not coming up
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Mar 21 2013 9:01AM
I have an cisco switch & summit 460,when the uplinks is conneted between cisco & extreme memeber of the uplink port is up & shows the status as ready.
for example:
I have bundled (2/14,3/14)  as port channel in cisco switch & enabled sharing on 47,48port of summit -460 switch,when i connected uplink to cisco switch port 47 comes up ,but port 48 does not come up & shows the status as Ready
can some sone help me on this.
the same scenario  work on other switches , but this switch stucks
(from venuprasad.kpm)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Mar 21 2013 1:19PM
Hello venuprasad.
Can you give us a little more information?  can you upload the config or do a show sharing command?  Are you using LACP or a static algorithm?
Thanks
P
(from Paul_Russo)
