shutdown radios over snmp
  • Question
  • Updated 8 months ago
  • Answered
I am trying to shutdown the access point radio over SNMP.
I have an OID from the MIB that says I should be able to do this, but I cannot find a value that will be acceptable.
The OID 1.3.6.1.4.1.388.50.1.3.34.2.1.5 - wingCfgAltDevIfShutdown, is showing the current setting of the radio, and is a Read-Write value.  It is Integer format, but I have no found a value that is acceptable using SNMPSET.
I enter "snmpset -r:(IP Address) -o:(OID stated above) -val:10", then I receive a badvalue(3) error.  I don't know what value is acceptable as a value of 1 in integer format.  Any suggestions?
This was done using snmpsoft.com snmpset function, AP7532, and WING 5.8.3 firmware.
Photo of Mark
Mark
  • 160 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 4,968 Points 4k badge 2x thumb
Hi Mark,
looks you have a wrong OID - this one is the one you are looking for
-- 1.3.6.1.4.1.388.50.1.3.18.3.1.1.5
		wingCfgDevIfShutdown OBJECT-TYPE
			SYNTAX TruthValue
			MAX-ACCESS read-write
			STATUS current
			DESCRIPTION
				XPath: /wing-config/device[mac=key1]/interface[name=key2]/shutdown"
			DEFVAL { false }
			::= { wingCfgDevIfEntry 5 }
OID you shared above is read-only and seems to be monitoring one.
Please try with correct OID and let me know.
Regards,
Ondrej
(Edited)
Mark,
seems we are both looking wrong way - this OID is for Ethernet interfaces.
Looking around in the MIB I found that snmpwalk on group 1.3.6.1.4.1.388.50.1.3.18.3.1.1 gives you overview of available interfaces
		wingCfgDevIfEntry OBJECT-TYPE
			SYNTAX WingCfgDevIfEntry
			MAX-ACCESS not-accessible
			STATUS current
			DESCRIPTION
				"An entry in the table."
			INDEX { wingCfgDevMac, wingCfgDevIfName }
			::= { wingCfgDevIfTable 1 }
But it does not give you direct value - (not accessible)
[smxmgr@localhost ~]$ snmpwalk -v2c -c public 88.88.88.83 1.3.6.1.4.1.388.50.1.3.18.3.1.1
SNMPv2-SMI::enterprises.388.50.1.3.18.3.1.1.1.132.36.141.24.150.92.6.114.97.100.105.111.49 = STRING: "radio1"
SNMPv2-SMI::enterprises.388.50.1.3.18.3.1.1.4.132.36.141.24.150.92.6.114.97.100.105.111.49 = STRING: "radio"
SNMPv2-SMI::enterprises.388.50.1.3.18.3.1.1.5.132.36.141.24.150.92.6.114.97.100.105.111.49 = INTEGER: 1
I am afraid there is no direct SNMP trap to shutdown the radio.
These are only radio control parameters you can use via SNMP
WingCfgDevIfRadioEntry ::=
 wingCfgDevIfRadioRfMode
 wingCfgDevIfRadioChannel
 wingCfgDevIfRadioPower
 wingCfgDevIfRadioPlacement
 wingCfgDevIfRadioBeaconInterval
 wingCfgDevIfRadioRtsThreshold
 wingCfgDevIfRadioOffChannelScan
 wingCfgDevIfRadioPreambleShort
 wingCfgDevIfRadioGuardInterval
 wingCfgDevIfRadioAmpduMode
 wingCfgDevIfRadioAmsduMode
 wingCfgDevIfRadioRifsMode
 wingCfgDevIfRadioAmpduMaxAggrSizeRx
 wingCfgDevIfRadioAmpduMaxAggrSizeTx
 wingCfgDevIfRadioAmpduMinSpacing
 wingCfgDevIfRadioAntennaMode
 wingCfgDevIfRadioNonUnicastForwarding
 wingCfgDevIfRadioDynamicChainSelection
 wingCfgDevIfRadioLockRfMode
 wingCfgDevIfRadioSnifferRedirHost
 wingCfgDevIfRadioSnifferRedirChannel
 wingCfgDevIfRadioMesh
 wingCfgDevIfRadioMeshLinks
 wingCfgDevIfRadioProbeResponseRetry
 wingCfgDevIfRadioProbeResponseRate
 wingCfgDevIfRadioMaxClients
 wingCfgDevIfRadioRadioTapMode
 wingCfgDevIfRadioWirelessClientPower
 wingCfgDevIfRadioLoadBalLfCount
 wingCfgDevIfRadioLoadBalLfThroughput
 wingCfgDevIfRadioLoadBalWmCount
 wingCfgDevIfRadioLoadBalWmTput
 wingCfgDevIfRadioAssocAcl
 wingCfgDevIfRadioQosPolicy
     wingCfgDevIfRadioAntennaDowntilt
     wingCfgDevIfRadioExtendedRange
 wingCfgDevIfRadioOperMode
 wingCfgDevIfRadioRates
 wingCfgDevIfRadioTransmitBeamforming
Regards,
Ondrej
(Edited)
Photo of Maik
Maik
  • 120 Points 100 badge 2x thumb
Hi guys, won't open a new thread, because my target maybe the same as marks. I just wanna shut down a wireless network (a SSID for guests) via snmp and re-enable if necessary.
I diff'ed the snmpwalks with enabled and disabled state and got the following OID:
 iso.3.6.1.4.1.388.50.1.4.3.2.10.1.1.15.7.100.101.102.97.117.108.116.20.56.52.45.50.52.45.56.68.45.56.57.45.65.52.45.53.52.58.82.49 = Gauge32: 0
iso.3.6.1.4.1.388.50.1.4.3.2.10.1.1.15.7.100.101.102.97.117.108.116.20.56.52.45.50.52.45.56.68.45.56.57.45.65.52.45.53.52.58.82.50 = Gauge32: 0
In enabled state both are 1, disabled zero. But the seems to be both read-only.
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 1,508 Points 1k badge 2x thumb
I am testing on WiNG v5.9.0, but believe the MIBs are the same. I am using the WING-MIB.mib file from the AP7522 v5.9.0 firmware zip file in conjunction to Ireasoning MIB Browser. I successfully can use the following to set the WLAN shutdown (integer, value = 1) and to re-enabled use integer, value = 2).
.1.3.6.1.4.1.388.50.1.3.4.1.1.3.4.87.80.65.50
-- 1.3.6.1.4.1.388.50.1.3.4.1.1.3
wingCfgWlanShutdown OBJECT-TYPE
SYNTAX TruthValue
STATUS current
DESCRIPTION
XPath: /wing-config/wlan[name=key1]/shutdown"
DEFVAL { false }
::= { wingCfgWlanEntry 3 }
Photo of Maik
Maik
Hey Christopher, I got it working, thanks fot that!
For a complete solution of my task, I need to view/change the PSK of wlan. Is there any value at the private community tree?
Photo of Maik
Maik
Any further ideas here?
Photo of Yurii Sulak
Yurii Sulak
  • 80 Points 75 badge 2x thumb
Hi Maik, try IF-MIB::ifDescr to define your wifi interface on device , than set this interface off by ifAdminStatus.
(Edited)
