Slot-2: Unable to Add L2 2:4 to s,G,v=ac12090c,e0000005,510 IPMC 13, unit 0 Entry not found
  • 2
  • Problem
  • Updated 4 years ago
Finding subjected error in BD-8806/15.3.3.5 p1-4.
Can someone help me understanding and resolving these error messages, its flooding log message space too.
Photo of Hardik
Hardik
  • 100 Points 100 badge 2x thumb
Posted 4 years ago
  • 2
Photo of Jason
Jason, Employee
  • 294 Points 250 badge 2x thumb
You should reach out to the Gtac and open a ticket
Photo of Hardik
Hardik
Thanks Jason !
Do you think these messages could be service impacting ?
BR//
Hardik
Photo of Jason Parker
Jason Parker, Employee
  • 3,018 Points 3k badge 2x thumb
I am searching the database since I have been here today and will get back to you
Could you send in a configuration or even the full log?
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
This log messages appear when there is mismatch between the h/w and s/w entries. When certain traffic comes to switch and if H/W entry is not present then that traffic would be process by CPU.
Photo of Hardik
Hardik
Hi Sumit,
Thanks for your reply, I know "debug hal..." command will get hardware entry. what is the way to find s/w entries ?
BR//
Hardik
Sumit Tokle, Alum
 "debug hal..." will not show the h/w entries.
You need to contact GTAC to report this issue.
debug hal show fdb may help
Please contact the GTAC as Tokle has stated so we can get to the bottom of the issue.
Photo of Thiago Ferreira
Thiago Ferreira
  • 60 Points
Hello guys, i'm having the same problem in network, where i work.
Anybody have a solution for the problem?
Photo of Drew C.
Drew C., Community Manager
  • 39,322 Points 20k badge 2x thumb
Hi Thiago,
There are a few causes for this particular problem.  As suggested above, I would recommend opening a case with GTAC so they can help point you in the right direction.  The most likely recommendation will be a software upgrade.
You can open a case online, or via phone:  http://www.extremenetworks.com/support
-Drew
