Slow input speed on putty with Exos Summit x250e 48p
Lazaro_Carrillo
I have ssh2 connection to one Exos Summit Extreme x250e 48p on my workplace but the issue is that when I connect to it using putty it takes a long time to write the commands. It stays like paused and after a while, it writes everything from one shot. Could you shed some light here, please? What should I do?
1 REPLY 1
Karthik_Mohando
Hi Lazaro,
To start with can you check if there is a high CPU situation?
use the "top" command and run it for a while and observe the situation.
If there is no high CPU, please enable telnet on temporary basis and see if you find the same slowness.
