SNMP apRadioFrequency client connection
  • Question
  • Updated 3 years ago
  • Answered
Im using snmp to query our WirelessController, is it possible to query the RadioFrequency a client is connecting by (2.4GHz or 5Gz). I found the snmp query tag 'apRadioFrequency = '1.3.6.1.4.1.4329.15.3.5.1.3.1.1' listed as part of the AccessPoint tags, but was not listed under the MobileUnits tags ...
These are the tags listed under the MobileUnits.
muMACAddress
muIPAddress
muUser
muState
muAPSerialNo
muVnsSSID
muTxPackets
muRxPackets
muTxOctets
muRxOctets
muDuration
muAPName
Is the connection frequency of a client captured and available via an snmp query?
Thanks
LIam
Photo of Liam O Donnell
Liam O Donnell
  • 148 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
You should be able to find it under 1.3.6.1.4.1.4329.15.3.1.4.1.1
Specifically..
1.3.6.1.4.1.4329.15.3.1.4.1.1.2
assocIfIndex OBJECT-TYPE
SYNTAX Integer {
    unknown(0),
    mode11A(1),
    mode11G(2),
    mode11B(3),
    modeN50(4),
    modeN24(5),
    mode11AC(6) }
(Edited)
Liam O Donnell
That worked great, I have one more query. Is it possible to query the channel No the Access point is using at any given time using an snmp query on the Wireless Controller?
I would like to be able to identify how often a waop changes channel.
Thanks
Liam
Photo of Doug Hyde
dot11ExtSmtCurrentChannel=1.3.6.1.4.1.4329.15.3.1.1.7.1.2
That should do it....
(Edited)
