SNMP ISsue with X450 and X670
  • Question
  • Updated 1 year ago
  • Answered
Hello,
i’m desperately trying to manage following switches via SNMPv3  with Extreme Netsight (X450 and X670). The software Version is:
-        summitX-22.2.1.5-patch1-4.xos
I’m facing the same issue software version
-        summitX-16.2.3.5.xos
Have anybody already run into the same issue? Any hint?
i also try  snmpv2 unsuccessful.
## sh snmpv3 group
Group Name      : groupRW
Security Name   : V3User
Security Model  : USM
Storage Type    : NonVolatile
Row Status      : Active
Thanks in advance.
Gradelain
Photo of Gradelain Ngouni
Gradelain Ngouni
  • 480 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Brian Anderson
Brian Anderson
  • 722 Points 500 badge 2x thumb
Based on what you have listed, I think the commands to put into the switch would be these:
configure snmpv3 add user V3User auth md5 <password> priv des <password>
configure snmpv3 add group groupRW user V3User sec-model usm
configure snmpv3 add access groupRW sec-model usm sec-level priv read-view defaultAdminView write-view defaultAdminView notify-view defaultNotifyView
enable snmp access snmpv3
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,034 Points 5k badge 2x thumb
Can you send us the command "show config snmp detail" You can remove any passwords if you have some in clear text.
Photo of Tooley, Akiko
Tooley, Akiko, Employee
  • 610 Points 500 badge 2x thumb
You can refer to the GTAC knowledge below in regards to how to setup SNMPv3 on EXOS and there is also a script that will help you delete the existing SNMPv3 configuration and create a new one based on your NetSight profile settings.
The location of the script is included in this article:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-set-up-SNMPv3-on-EXOS
