SNMP + LAG
  • Question
  • Updated 3 years ago
  • Doesn't Need an Answer
Hi, all!
After adding LAG on port from which was received VLAN monitoring (through SNMP) all counters became zero.
Is this a limitation or bug?
I mean that now I have information about port but can't have information about vlan.
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,670 Points 10k badge 2x thumb
Posted 3 years ago
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Alexandr,
can you please confirm the below understanding?
you have enabled the VLAN monitoring on all the ports of a VLAN. You were able to fetch this information via SNMP without any issues.
The port is now added as a LAG port and not a standalone port. After this change, the SNMP is no longer able to fetch the VLAN statistics. Is that correct?
if I understood this right, can you please check from the CLI of the switch, if the VLAN statistics still works for that port?
Please share the following outputs:
show VLAN statistics
show conf | include monitor
show port <port number> information detail.
Model and the software version of the switch.
Looking forward to your response!
