SNMP OID for port rate-limit?
  • Question
  • Updated 1 year ago
  • Answered
Quick question: There wouldn't happen to be an SNMP OID to query a port's rate-limit on Extreme switches? If there is, could anyone tell me what that might be?
I set "config port 4 rate-limit egress 100000 Kbps" - now I want to snmp-get/walk something to see that tit's at 100000
Thanks!
Photo of Frank
Frank
  • 3,776 Points 3k badge 2x thumb
Posted 3 years ago
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Hi Frank,
There are two tables in the MIB that may give you what you're looking for.
I'm looking at the EXOS 15.5 MIB and I see a table called extremePortEgressRateLimitEntry
It starts at OID .1.3.6.1.4.1.1916.1.4.9
You should be able to query .1.3.6.1.4.1.1916.1.4.9.1.2.1004  (that's port number 4+1000) to see the extremePortEgressRateLimitValue as an integer.  It's not working for me on my test switch right now, but it's got a minimal configuration and some beta code loaded.
Photo of Frank
Frank
Sniff:
# snmpwalk -On -v2c -cpublic MySwitch .1.3.6.1.4.1.1916.1.4.9
.1.3.6.1.4.1.1916.1.4.9 = No Such Object available on this agent at this OID
On both 15.5.2.9 and 15.5.3.4 patch1-6 (on 460s)
Guess it's an optimistic MIB - or do I perhaps have to configure some setting to "on" ?
Thanks for your reply!
Photo of Drew C.
Hmm, I wonder if it is supposed to work or if support has been discontinued for some reason.
Would you be willing/able to open a support ticket on this issue so that GTAC can help figure out what's going on?
Photo of Roberto F.
Roberto F.
  • 690 Points 500 badge 2x thumb
I have the same needs and problem ...
snmpwalk -v 2c -c public XX.XX.XX.XX 1.3.6.1.4.1.1916.1.4.9.1.2
iso.3.6.1.4.1.1916.1.4.9.1.2 = No Such Object available on this agent at this OID
snmpwalk -v 2c -c public XX.XX.XX.XX 1.3.6.1.4.1.1916.1.4.16
iso.3.6.1.4.1.1916.1.4.16 = No Such Object available on this agent at this OID
The switch are
iso.3.6.1.2.1.1.1.0 = STRING: "ExtremeXOS (X460-24t) version 15.5.4.2 v1554b2 by release-manager on Thu Apr 2 14:19:36 EDT 2015"
Someone have a solution?
Photo of Frank
Frank
Ack - sorry for not feeding the case reply back in here. The reply was:
"...It looks like the functionality was planned and the appropriate values were added to the MIB, but it has not actually been implemented yet. If you look in the EXOS 15.7 User Guide for "extremePortEgressRateLimitTable" it lists it as "Not supported". So, the functionality isn't quite there yet."
Photo of Lars Kristian
Lars Kristian
  • 80 Points 75 badge 2x thumb
Anyone know when the "extremePortEgressRateLimitTable" is going to be implemented?
As an ISP, we need it to review subscriptions in our network..
