SNMP Receiver Not Able to Pull MAC Address and Other Info from BlackDiamond and Stacked Summit Switches
  • Problem
  • Updated 3 years ago
  • Solved
Hello Everyone,
I am currently having an issue pulling device info from my Blackdiamond cores and stacked Summit series switches via SNMP (Both v2 and V3 produce same results). My non-stacked Summit series switches are not experiencing this issue and are pulling all info as expected. SNMPv2 is configured the same on all switches in our environment. I am only trying to pull basic information such as device info (sysname, contact, MAC, etc) and port mappings. However when I scan the problematic switches SNMP does not return the mac address for the device and the port status is a consistent "testing" state. It will pull other basic information and pull the macs associated with each port but not the mac of the switch itself. This is causing an issue because I now have one asset for each IP I've assigned to my cores. The tool I am using to gather information is LANsweeper, I initially contacted them about the issue but they seem to think it is a firmware issue on the switch itself. As mentioned earlier this is happening on all four of my blackdiamond switches and all stacked summit switches. I have about 50+ non-stacked summit switches that are able to pull snmp correctly. Any suggestions I'm running out of ideas? I have posted screen shots below of a good and bad SNMP pull.
Thank You,
Photo of Kevin Craig
Kevin Craig
  • 150 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,076 Points 5k badge 2x thumb
Kevin Craig
MEC01-BD8806-01.2 # show configuration "snmp"#
# Module snmpMaster configuration.
configure snmpv3 add community squarepants encrypted name qv}`{ev`g|v user v1v2c_ro
configure snmpv3 add target-addr v1v2cNotifyTAddr1 param v1v2cNotifyParam1 ipaddress 10.102.2.4 transport-port 10550 from 10.102.0.75 tag-list defaultNotify
configure snmpv3 target-addr v1v2cNotifyTAddr1 retry 0
configure snmpv3 add target-addr v1v2cNotifyTAddr2 param v1v2cNotifyParam2 ipaddress 10.102.2.88 transport-port 162 tag-list defaultNotify
configure snmpv3 add target-params v1v2cNotifyParam1 user v1v2cNotifyUser1 mp-model snmpv2c sec-model snmpv2c sec-level noauth
configure snmpv3 add target-params v1v2cNotifyParam2 user v1v2cNotifyUser2 mp-model snmpv2c sec-model snmpv2c sec-level noauth
configure snmp access-profile snmp_access readwrite
Kevin Craig
Firmware version on Blackdiamonds is 15.3.3.5
Most Summit Switches Firmware 12.5.4.5 some with 15.3.4.6
If you poll for the below OID's do they work?
Slot 1 MAC   -  .1.3.6.1.4.1.1916.1.33.2.1.6.1
Slot 2 MAC   -  .1.3.6.1.4.1.1916.1.33.2.1.6.2
Slot 3 MAC   -  .1.3.6.1.4.1.1916.1.33.2.1.6.3
Slot 4 MAC   -  .1.3.6.1.4.1.1916.1.33.2.1.6.4
Kevin Craig
..1.3.6.1.4.1.1916.1.33.2.1.6.1
Paessler SNMP Tester 5.1.3
6/8/2015 2:04:56 PM (6 ms) : Device: 10.102.0.75
6/8/2015 2:04:56 PM (10 ms) : SNMP V2c
6/8/2015 2:04:56 PM (13 ms) : Custom OID .1.3.6.1.4.1.1916.1.33.2.1.6.1
6/8/2015 2:04:56 PM (24 ms) : -------
6/8/2015 2:04:56 PM (28 ms) : Value: No such object (SNMP error # 222)
6/8/2015 2:04:56 PM (31 ms) : Done
6/8/2015 2:06:08 PM (9 ms) : Device: 10.102.0.75
6/8/2015 2:06:08 PM (13 ms) : SNMP V2c
6/8/2015 2:06:08 PM (17 ms) : Custom OID .1.3.6.1.4.1.1916.1.33.2.1.6.2
6/8/2015 2:06:08 PM (39 ms) : -------
6/8/2015 2:06:08 PM (51 ms) : Value: No such object (SNMP error # 222)
6/8/2015 2:06:08 PM (60 ms) : Done
6/8/2015 2:06:37 PM (15 ms) : Device: 10.102.0.75
6/8/2015 2:06:37 PM (22 ms) : SNMP V2c
6/8/2015 2:06:37 PM (29 ms) : Custom OID .1.3.6.1.4.1.1916.1.33.2.1.6.3
6/8/2015 2:06:37 PM (175 ms) : -------
6/8/2015 2:06:37 PM (182 ms) : Value: No such object (SNMP error # 222)
6/8/2015 2:06:37 PM (190 ms) : Done
6/8/2015 2:06:37 PM (29 ms) : Custom OID .1.3.6.1.4.1.1916.1.33.2.1.6.4
Kevin,
Sorry for such a delayed response.  I downgraded a summit stack to 15.3.4.6 to make sure it was not a SW version issue, and these OID's did work when I was using ireasoning mib browser.  You can try to poll the switch for OUI's through the CLI.  Could you try doing this to make sure it works.
Also, are you trying to get the slot MAC's from the BD slots or a summit stack slot?  These OID's are for summit stacking slots.
Slot-1# show snmp get 1.3.6.1.4.1.1916.1.33.2.1.6.1
extremeStackable.2.1.6.1 = 00 04 96 52 ec 81
Slot-1# show snmp get 1.3.6.1.4.1.1916.1.33.2.1.6.2
extremeStackable.2.1.6.2 = 00 04 96 52 ec 78
Slot-1# show version
Slot-1      : 800478-00-01 1150G-00095 Rev 1.0 BootROM: 2.0.1.5    IMG: 15.3.4.6
Slot-2      : 800478-00-01 1150G-00096 Rev 1.0 BootROM: 2.0.1.5    IMG: 15.3.4.6
Slot-3      :
Slot-4      :
Slot-5      :
Slot-6      :
Slot-7      :
Slot-8      :
Image   : ExtremeXOS version 15.3.4.6 v1534b6 by release-manager
          on Fri Aug 1 10:27:53 EDT 2014
BootROM : 2.0.1.5
Diagnostics : 5.10
Slot-1# show stacking
Stack Topology is a Ring
Active Topology is a Ring
Node MAC Address    Slot  Stack State  Role     Flags
*00:04:96:52:ec:81  1     Active       Master   CA-
 00:04:96:52:ec:78  2     Active       Backup   CA-
* - Indicates this node
Flags:  (C) Candidate for this active topology, (A) Active Node
        (O) node may be in Other active topology
(Edited)
