SNMP - stack-ports and switch utilization
  • Question
  • Updated 3 years ago
  • Answered
Hello, colleagues!
Hav e 2 questions:
1. Is there possibility to monitoring recources utilization through SNMP? (like arp-table, routing table, fdb)
2. Is there possibility to monitoring productivity of stack-ports?
In EXOS User Guide there is no MIBs for stack ports in Ch.50 - Supported MIBs.
But there is in stack configuration chapter - Setting Traps for Stacking and there is a lot of MIBs for EXTREME-STACKING-MIB in MIB.txt
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,576 Points 10k badge 2x thumb
Posted 3 years ago
Photo of Alexandr P
P.S. For Summit switches
Photo of Alexandr P
Any ideas?
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Hi Alexandr,
Are you wanting to see entries in the tables?
The extremeFdbIpFdbTable @ OID .1.3.6.1.4.1.1916.1.16.2 gives you MAC Address, IP address, VLAN ID, and port number.   It's almost the same as show iparp.  I don't see any OID for showing utilization/limits, but it's possible that I missed one.
For stack ports, do you want to see the utilization and link status?
That might be in extremePortUtilizationTable @ OID .1.3.6.1.4.1.1916.1.4.5
Might also find information in extremeStackingPortTable @ OID .1.3.6.1.4.1.1916.1.33.3
The switch I'm testing these on isn't stacked, so I'm not sure.
I hope this helps!
Photo of Alexandr P
Hi, Drew!
I find the same:
2.
• extremeStackingPortStatusChanged
• IfIndex: Interface Index of the port
• extremeStackingPortRemoteMac: MAC Address of the remote switch attached to this port
• extremeStackingPortLinkSpeed: Indicates 10/100/1000 Mbps
• extremeStackingPortLinkStatus: Status of the link
3.
EXTREME-FDB-MIB
extremeCpuMonitorTotalUtilization
extremeMemoryMonitorSystem
But Customer want:
2 - tx/rx frames, errors on stack ports
3 - limited recources of switch (fdb I find too, but there is also quantity of routes, arp, neigbours... - to see, when there overflow of limited resources)
Thank you!
Photo of Drew C.
I don't see anything in the MIB for that information.  The only option I can think of right now is logging into the switch and collecting it via script.
Photo of Alexandr P
Thank you, Drew!
