SNMP Vlan Total Traffic
  • Question
  • Updated 3 years ago
Hello guys,
I have two problems.
1st - I need to create a graph based on datas collected by snmp of full traffic about a specific vlan, then, i've enable the command "configure ports all monitor vlan XXX" at extreme x440 to i can pull the informations using snmpwalk to try and get see the counters be increasing.
However, when i put the command "sh vlan statistics", i can't able to see traffic in TX, i see just RX be increasing.
2nd - Is there any OID specific to get full traffic of a vlan, instead vlan by port?
Tks
Welisson
Photo of welisson
welisson
  • 908 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
Welisson,
Summit X440 only supports receive statistics.
In EXOS Command Reference, the entry for
configure ports monitor vlan
indicates that TX statistics are only available for BD X8, BD 8900 and Summit X460/X480/X670, while RX statistics are available for BD X8, BD 8K and all Summit switches..
Photo of welisson
welisson
Daniel,
i'm so frustrated after heard it, because i'd already tried get this information with Extreme, and they never told me it. :-(
Tks for your reply, and if you can answer other question will help me so much.
Do you know if there is any MIB to accounting traffic total each vlan?
Unfortunately, there's no MIB variable for total traffic in a VLAN. Only per port counts.
All MIB info is in the documentation also... http://documentation.extremenetworks.com/exos/downloads/EXOS_User_Guide_15_6.pdf, Chapter 50 EXOS Configuration
Management Enhancements.
In page 1683 you'll find all variables for the private EXTREME-VLAN-MIB.
