So many TXerror
  • Question
  • Updated 3 years ago
Why would i been receiving error on Txerrors.
Tx coll and Tx Deferred, should they not be the same count if the collision occurs and the packet is deferred?
Port Tx Error Monitor
Port      Link      Tx          Tx          Tx          Tx       Tx       Tx
          State     Coll        Late coll   Deferred    Errors   Lost     Parity
1         R         0            0           0         0         0         0
2         A      1530            0        2639         0         0         0
3         R         0            0           0         0         0         0
Thanks
Photo of JeremyClarkson
JeremyClarkson
  • 1,010 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Christoph
Christoph
  • 1,812 Points 1k badge 2x thumb
It it's twisted pair, first check cables, connector and length.
Than check autoneg,, speed and duplex settings on both ends.
JeremyClarkson
Everything is auto neg,
why would you recommend the cable, have you seen this error before?
Thanks
Photo of Christoph
Christoph
If both sides on autoneg, verify that they choose and run on the same speed and duplex settings.
Late collusions meens the first bytes of the packet were send but then another one also starts sending during the medium is still occupied.
It's typical for 10 Mbit/s with duplex mismatches.
But it also can be caused by a short circuit or something.
