Some clients fail to connect until AP rebooted
  • 3
  • Problem
  • Updated 2 months ago
  • Solved
I have the V2110 controller and a bunch of AP3825's in my network. Periodically I will hear about someone who is having trouble connecting (either a new client, or an existing client that had previously associated).
It started with an iPad where once a month it wouldn't see the AP. But when they'd bring me the iPad it would work when it was connected to the AP in my office. I finally got to troubleshoot it on site but it wouldn't connect. I told it to forget the network and when I attempted to add it back, it would tell me the password was incorrect. But I walk it down to my office and it would accept the password. I discovered the following web site, but I had already enabled that feature to no avail:
https://gtacknowledge.extremenetworks.com/articles/Solution/Apple-IOS-Clients-with-Connection-Issues...
Now it seems to be happening to various devices that are connected to various APs. Today a Windows laptop wouldn't associate. I rebooted the AP and then it would accept the password.
We're running 9.21.15.0006. I'm hoping there is a known bug and all we have to do is upgrade.
I haven't upgraded yet because I still have some AP3660s in the field- I don't believe they are compatible with 10. I'm working on removing/replacing these.
Thanks.
Photo of T Pitch
T Pitch
  • 140 Points 100 badge 2x thumb
Posted 3 months ago
  • 3
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,434 Points 20k badge 2x thumb
You'd least upgrade to v9.21.19.
What auth/privacy is used on the WLAN service.
Photo of T Pitch
T Pitch
It actually happens on many WLAN services- they're all WPA2-PSK no no auth policy.
- is it set to WPAv2 AES only or auto
- is WPAv1 disabled
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,280 Points 2k badge 2x thumb
Hi  Thomas,
try it with disable d Management Frame Protection: (MFP ) .
It's enabled by default.
WLAN Services->Privacy -> Management Frame Protection:
Regards
Umut Aydin
Photo of T Pitch
T Pitch
Ronald,
Actually both. One has WPAv1/TKIP and WPAv2/Auto while the other has only WPAv2/Auto. Both networks experience the same issues.
Umut,
I actually have it disabled when my most recent user reported trouble connecting. It wasn't until I rebooted the AP before they could connect.
Photo of Umut Aydin
Hi Thomas,
OK..I would go with the FW Upgrade to v9.21.19 if not done.( Here is some major fixes / Memory and stability related issues)
v9.21.20 is GA and will be available in some days over the portal page.
Maybe to go directly to this code.
See also
https://gtacknowledge.extremenetworks.com/articles/How_To/05-11-18-IPAD-2-connectivity-issues-on-AP3...
After the update I would suggest to open a Case within GTAC.
Regards
Umut
