some devices return "sh: ./sftp: not found" when firmware upgrade via scp2
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
We were in a process of updating EXOS switches via Netsight script and we noticed some switches have not been upgraded. These set of switches have EXOS ver 21.1.0.17
Then I manually tried to upgrade using
scp2 vr "VR-Default" root@<IP>:/root/firmware/images/summitX-21.1.1.4-patch1-5.xos summitX-21.1.1.4-patch1-5.xos
and it returns "sh: ./sftp: not found" .  Any idea to fix this ?
Photo of Weda
Weda
  • 994 Points 500 badge 2x thumb
Posted 2 years ago
Photo of OscarK
OscarK, ESE
  • 7,792 Points 5k badge 2x thumb
21.1.0.17 is a beta version of EXOS, maybe the internal sftp part was not yet included in that version, I would advise using normal tftp to do the upgrade on these switches.
Photo of Weda
Weda
Thanks for your reply.
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
Please find below the steps to upgrade the switches using EXOS procedure:
Software upgrade procedure:
    Download the appropriate EXOS image.
    Place the EXOS image on a TFTP server.
    Ensure that you are able to ping the TFTP server from the switch from the appropriate virtual router. At least one of ping vr vr-Mgmt <host> or ping vr vr-Default <host> operations must successfully reach your TFTP server before you can proceed. After verifying the TFTP server is reachable, specify that VR when you download the image in the next step.
    Type the command download image <host> <filename.xos> <virtual-router>.
    Reboot the system for the upgrade to take effect: Type reboot, then when asked if you want to reboot the switch now, type yes.
Additional Notes:
    If upgrading a BlackDiamond chassis with two MSMs, then follow the steps above only on the Master MSM – after which it will automatically synchronize with the Backup.
    It is unnecessary to specify the partition on which to load the new image, because by default it will be downloaded and installed on the non-active partition.
    If XMODs are utilized in your environment, then install them prior to rebooting.
Photo of Drew C.
Drew C., Community Manager
  • 38,450 Points 20k badge 2x thumb
