Speed Negotiation
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Hi Team,
I am using x670-48t switches and all of the ports available are of 1G/10G speed.But the device with which I want to connect has a port of speed 100 mbps.
When I am trying to downgrade the port speed to 100 mbps using command :
configure ports 21 auto on speed 100 duplex full or
configure ports 21 auto off speed 1000 duplex full
It throws an error mentioning the port does not support 100 Mbps.
Is there any way by which I can downgrade the port speed to 100 Mbps.
With Regards,
Kalyan  Brata Majumder.
Photo of Kalyan Majumder
Kalyan Majumder
  • 230 Points 100 badge 2x thumb
Posted 3 years ago
Photo of andreas
andreas
  • 1,218 Points 1k badge 2x thumb
No the chipset behind the port dosent support this.
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,290 Points 3k badge 2x thumb
Hi Kalyan,
I was able to successfully hardcode the speed to 100Mbps on port# 3 in a X670V-48t
Command used to execute:-
* SW3.4 # conf port 3 auto off speed 100 dup full
* SW3.6 # show port 3 inf detail
Port:   3
        Virtual-router: VR-Default
        Type:           UTP
        Random Early drop:      Unsupported
        Admin state:    Enabled with  100M full-duplex
        Link State:     Ready
        Link Ups:       0        Last: --
        Link Downs:     0        Last: --
        VLAN cfg:
                 Name: remote_vlan, 802.1Q Tag = 1000, MAC-limit = No-limit, Vir                               tual router:   VR-Default
                       Port-specific VLAN ID: 1000
        STP cfg:
        Protocol:
        Trunking:       Load sharing is not enabled.
        EDP:            Enabled
        EEE:            Disabled
        ELSM:           Disabled
        Ethernet OAM:           Disabled
        Learning:       Enabled
What is the software version running on the X670v-48t switch?
Kalyan,
In addition to the EXOS Release, please share the output of  "show port 21 configuration no-refresh".
