speed problem
  • Question
  • Updated 4 years ago
We are Using 20 wireless extreme AP-4521 also we  configured virtual controller. Our all client pc are connecting only 65 mpbs speed. its possible to increase ....we are feel very slow
Photo of Mohammed Jasheer
Mohammed Jasheer
  • 916 Points 500 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Mohammed
Are all of the SSIDs set to bridge local?  Also what standard are you using ?  N?
P
Mohammed Jasheer
Hi Paul
                    yes all SSID set to bridge local. we are using N Standard also
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,880 Points 20k badge 2x thumb
As you've mentioned the max speed right now is 65Mb which is an 802.11n speed so I wonder whether your clients don't support higher speeds.
For example my old IPad also runs on 65Mb max as the WLAN adapter doesn't support more.
Another reason for low connection speed could be low signal strenght- so could you try with a 802.11n notebook directly beside the AP and tell us the results.
Mohammed Jasheer
Hi Ronald,
                       We are using latest Dell Laptops its support up to N standard moreover we accessing WiFi very closer of the device .That time also  same thinks is happening.  if u have any idea...
