ssh connection refused to switch but ssh is enabled on management
  • Problem
  • Updated 3 years ago
  • Solved
One switch in particular isn't allowing ssh connections, it doesn't show anything on switch logs, SSH is enabled with no access profiles, the private key is present and the switch configuration is the same as other switches.
Could someone advise of a troubleshooting step that doesn't involved reboot, ive run ssh update command with no change.
Photo of Stephanos
Stephanos
  • 94 Points 75 badge 2x thumb
Posted 3 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
Official Response
There was another query opened for similar issue which is solved now
https://community.extremenetworks.com/extreme/topics/impossible-to-activate-ssh-in-extreme-x450a-48t...
Could you past show version images
