SSH key-based auth to 7100-Series problem
  • Problem
  • Updated 2 years ago
  • Solved
  • (Edited)
Hey,
Please tell me the following is not normal:
1) Pubkey auth is enabled and password auth disabled.
2) I am not using any private key at all! (no ssh -i "private_key" here)
3) I can login with the password only.
71(rw)->show ssh
SSH Server:
 State: Enabled
 Host key type: RSA
 Allowed Ciphers List (default):
  aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,aes192-cbc,aes256-cbc,3des-cbc,
  blowfish-cbc,cast128-cbc,(email address removed by admin)
 Allowed MACs List (default):
  hmac-sha1-etm@openssh.com,hmac-md5-etm@openssh.com,
  hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,
  hmac-md5-96-etm@openssh.com,hmac-sha1,hmac-md5,hmac-ripemd160,
  hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
 Allowed Authentication Methods:
  password: disabled
  pubkey:   enabled
 PKI Trusted CA List:
 PKI Authorized Cert List:
 Authorized User Public Keys:
  Username         Type Bits Public Key
  rw               RSA  2048 x
SSH Client:
 Client alive interval: 30
 Client alive count: 5
71(rw)->exit
Connection to 1.2.3.4 closed.
root@nms:~$ ssh rw@1.2.3.4
Pubkey AUTHENTICATION succeeded, please enter rw's Password for AUTHORIZATION.
Password:
B O N D E D   7 1 0 0 - S E R I E S
Extreme Networks, Inc.
145 Rio Robles
San Jose, CA 95134
Phone:  +1 408 579-2800
E-mail: support@extremenetworks.com
WWW:    http://www.extremenetworks.com
(c) Copyright Extreme Networks, Inc. 2015
Chassis Firmware Revision:  08.42.01.0005
NB. Please fix usage of the "pre" button for multi-line input.
Photo of jeronimo
jeronimo
  • 1,198 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Drew C.
Drew C., Community Manager
  • 38,494 Points 20k badge 2x thumb
I've fixed the formatting in your post, I know it's quirky.  It works well if you click the <pre> button before pasting in your text.  Rather than unselecting the button when done, just click elsewhere to move your cursor out of the <pre> area.
Photo of jeronimo
jeronimo
Oups, id_rsa is the default private key file used by ssh. Mea culpa.
However this still does not solve my problem:
root@nms:~/.ssh$ ssh rw@1.2.3.4 show conf
Write failed: Broken pipe
How to run commands "unattended"? (Without using expect!)
(Edited)
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,886 Points 10k badge 2x thumb
I did not find a way w/o expect for the S-Series EOS (used on the 7100 as well), see https://community.extremenetworks.com/extreme/topics/connectionproblems-with-plink-putty-for-command... :-(
