ssl downgrade by default?
  • Problem
  • Updated 2 years ago
  • Solved
Hey guys,
When we ssh into a default install of exos, we're receving what appears to be a downgrade to a weak cipher/key exchange protocol:
Unable to negotiate with 10.xx.xx.xx port 22: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1
Do you know when this might be fixed?
Photo of shampoo
shampoo
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
What version of EXOS are you seeing this on? Also, what SSH client are you using?
-Brandon
Photo of shampoo
shampoo
Hey Brandon,
We're seeing this on v15.7.14 and are just using the terminal ssh client on Fedora 23
Thanks
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Ahh yes.. This is what I do
ssh -oHostKeyAlgorithms=+ssh-dss  -l USERNAME IPADDRESS
Should be able to add this to your ~/.ssh/config
HostkeyAlgorithms +ssh-dss
That way you don't have to type in the -oHostKeyAlg...
