SSL module for x450a24t in home lab environment
  • Question
  • Updated 10 months ago
  • Doesn't Need an Answer
  • (Edited)
Hi there, i have an x450a24t in a home lab environment, and as such have no warranty or support on this device.I am looking to get HTTPS access setup and I believe i need the ssl module to do this.Does anybody have a copy of this they might be able to let me have or point in the right direction to be able to down load this module it would be much appreciated.Many thanks,Peter
Photo of Peter Millard
Peter Millard
  • 210 Points 100 badge 2x thumb
Posted 10 months ago
Photo of Ariyakudi Srinivas, Muthuraman
Ariyakudi Srinivas, Muthuraman, Employee
  • 964 Points 500 badge 2x thumb
Hi Peter,
Please try to log into the download portal and check if you still have the last software available for download at the time of contract expiry with the switch serial number.
The below is the link to the download portal,
https://extremeportal.force.com/ExtrLogin?startURL=%2FExtrDownloadLanding
Peter Millard
Yeah I have done. There is nothing there for this switch.
Hi Peter,
I cannot think of a way except the software be made available for this serial number with a proper contract.
Photo of Drew C.
Drew C., Community Manager
  • 37,366 Points 20k badge 2x thumb
With the SSH module installed, try the steps in this article: https://extremeportal.force.com/ExtrArticleDetail?n=000001266
Peter Millard
Hi there,
Tried the instructions in the document but it keeps saying ssl module not installed.
Have verified that the ssh module is installed and running.
Many thanks
Peter Millard
Just wondering if anyone might be able to shed some light as to why the above article didn't work?
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,266 Points 3k badge 2x thumb
Hi Peter,
Can you provide the results of a "show version images", "show switch" and "show management"? Please redact any personal information that may be in those outputs. I'm mainly just concerned with the active switch partition, if the xmod is installed, and if its applied to the switch.
Thanks
Brad
Peter Millard
Here you go:-
Home_X450a-24t.1 # show version images
Card  Partition     Installation Date        Version     Name      Branch
Switch primary   Fri Aug 18 07:48:53 UTC 2017 15.3.5.2 summitX-15.3.5.2-patch1-14.xos v1535b2-patch1-14
Switch primary   Wed Aug 23 08:02:43 UTC 2017 15.3.5.2 summitX-15.3.5.2-patch1-14-ssh.xmod v1535b2-patch1-14
Switch secondary Fri Mar 23 18:55:42 UTC 2012 12.6.2.10 summitX-12.6.2.10-patch1-2.xos v1262b10-patch1-2
Switch secondary Thu Sep 20 21:18:17 BST 2012 12.6.2.10 summitX-12.6.2.10-patch1-2-ssh.xmod v1262b10-patch1-2
Home_X450a-24t.2 # show switch
SysName:          Home_X450a-24t
SysLocation:
SysContact:
System MAC:       00:04:96:51:AB:71
System Type:      X450a-24t
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Fri Sep  1 21:09:08 2017
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time:        Mon Aug 28 05:50:02 2017
Boot Count:       33
Next Reboot:      None scheduled
System UpTime:    4 days 15 hours 19 minutes 6 seconds
Current State:    OPERATIONAL
Image Selected:   primary
Image Booted:     primary
Primary ver:      15.3.5.2
                  patch1-14
Secondary ver:    12.6.2.10
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 15.3.5.2
                  179524 bytes saved on Fri Aug 25 20:27:23 2017
Home_X450a-24t.3 # show man
[KHome_X450a-24t.3 # show management
CLI idle timeout                 : Enabled (20 minutes)
CLI max number of login attempts : 3
CLI max number of sessions       : 8
CLI paging                       : Enabled (this session only)
CLI space-completion             : Disabled (this session only)
CLI configuration logging        : Disabled
CLI scripting                    : Disabled (this session only)
CLI scripting error mode         : Ignore-Error (this session only)
CLI persistent mode              : Persistent (this session only)
CLI prompting                    : Enabled (this session only)
Telnet access                    : Enabled (tcp port 23 vr all)
                                 : Access Profile : not set
SSH access                       : Enabled (Key valid, tcp port 22 vr all)
Web access                       : Enabled (tcp port 80)
Total Read Only Communities  : 1
Total Read Write Communities  : 1
RMON                             : Disabled
SNMP access                      : Disabled
SNMP Compatibility Options       :
    GETBULK Reply Too Big Action : Too Big Error
IP Fragmentation             : Disallow
SNMP Notifications               : Enabled
SNMP Notification Receivers  : None
SNMP stats: InPkts 0       OutPkts   0       Errors 0       AuthErrors 0
  Gets   0       GetNexts  0       Sets   0       Drops      0
SNMP traps: Sent   0       AuthTraps Enabled
SNMP inform: Sent   0       Retries   0       Failed 0
Home_X450a-24t.4 #
Many thanks
