STACK reboot issue
  • Question
  • Updated 1 year ago
  • Answered
I also have a problem with an unexpected reboot.
X440-G2-24t. 21.1.1.4 Patch 1-5.
All works but then backup switch reboots when one of the stack cables are disconnected.
Photo of sukwinder gill
sukwinder gill
  • 110 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,442 Points 3k badge 2x thumb
Hi ,
What is the current status of stack?
Do you see any dual master situation in stack?
Please check below article.
https://gtacknowledge.extremenetworks.com/articles/Solution/X440-X460-dual-stack-master
Thanks,
Suresh.B
sukwinder gill
* Slot-1 Stack.8 # sh stackingStack Topology is a Daisy-Chain
Active Topology is a Daisy-Chain
Node MAC Address    Slot  Stack State  Role     Flags
*00:04:96:9b:ba:06  1     Active       Master   CA-
 00:04:96:9b:ba:24  2     Active       Standby  CA-
sukwinder gill
Please advice
Photo of Tooley, Akiko
Tooley, Akiko, Employee
  • 600 Points 500 badge 2x thumb
What does the "show log" and "show log messages nvram" output display at the time the issue is happening?
Do you see any CRC errors on the stack ports? You can determine that by running the command: "show ports stack-ports rxerrors"
It is recommended to use a ring topology instead of daisy-chain. Please see the GTAC knowledge article below: https://gtacknowledge.extremenetworks.com/articles/Q_A/What-is-the-benefit-of-using-a-ring-topology-...
Photo of Hernandez, Joshua
Hernandez, Joshua, Employee
  • 1,564 Points 1k badge 2x thumb
Is this in reference to the posted output to show stacking found on this thread Help! Stack unexpected reboot
If so, consider the output previously posted and understand that if the stack is still in a master / standby configuration and daisy chain.  The assumption is that there is only 1 stack cable connecting the nodes.  This means if standby looses connection to its master for any reason (in this case disconnecting the stack cable) it will reboot because it is not master capable and relies on communication to a master.
