Stacked switches has no Back-up configured: How to?
  • 2
  • Question
  • Updated 4 years ago
I would just want to ask how to configure back-up role in switches configured as stacked. See below output:
show switch
SysName:
SysLocation:
SysContact:       support@extremenetworks.com, +1 888 257 3000
System MAC:       02:04:96:83:4E:A1
System Type:      X450a-48t (Stack)
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Wed Jul 23 14:13:17 2014
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time:        Fri Oct 11 10:55:01 2013
Boot Count:       24
Next Reboot:      None scheduled
System UpTime:    285 days 3 hours 18 minutes 16 seconds
Slot:             Slot-1 *                     No Backup
Current State:    MASTER
Image Selected:   primary
Image Booted:     primary
Primary ver:      15.3.2.11
                  patch1-2
Secondary ver:    12.5.4.5
Config Selected:  sw2-stack.cfg
Config Booted:    sw2-stack.cfg
sw2-stack.cfg     Created by ExtremeXOS version 15.3.2.11
                  1114713 bytes saved on Wed Jul  9 14:47:31 2014
Slot-1 PIDC-CORE-CHSW-02.7 #
Node MAC Address    Slot  Stack State  Role     Flags
*00:04:96:83:4e:a1  1     Active       Master   CA-
 00:04:96:83:4e:b5  2     Active       Standby  CA-
 00:04:96:83:4e:a2  3     Active       Standby  CA-
 00:04:96:83:4e:a8  4     Active       Standby  CA-
thank you,
James
Photo of James Red
James Red
  • 322 Points 250 badge 2x thumb
Posted 4 years ago
  • 2
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello James
The command is configure stacking redundancy minimal
Let me know if that helps answer your question
Photo of showospf
showospf
  • 102 Points 100 badge 2x thumb
I am having the same issue...i have 2 x670 + 2 x460 configured in a stack. initially i had a master, backup and two standby, but now when i look at the stacking i am seeing two Masters and two standby.
@Paul R will this command "configure stacking redundancy minimal" solve the dual master issue? After rebooting the stack, it went back to master + backup but i am afraid it will happen again.
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Please refer FN404 for X460 stacking issues. You can get FN404 after login into esupport.extremenetworks.com
Photo of James Red
James Red
Hi Paul,
Thanks for the reply. configure stacking redundancy minimal + reboot did the trick.
James
