Stacking 2 Switches
  • Question
  • Updated 4 years ago
Hi All,
I'm just looking in the requirements for stacking 2 Summit devices. 1 is an x440-48p the other an x440-24p.
Can someone confirm that we require 2 Stack cables, which would be connected as a 1-2 & 2-1 configuration between the devices. A colleague is adamant that we only need one cable.
I understand the software needs to be the same on both device. Are there any other points of reference that I need to deal with before progressing?
Thanks in advance for the assistance.
Jason
Photo of Jason Short
Jason Short
  • 390 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Jason
If you only have two switches then one cable is enough, however I always recommend two cables in case a cable or stack port goes bad.
As you move up in the number of switches in the stack you always want to have all ports connected in a ring architecture .
My preference is 2 but since you only have 2 switches you won't get the benefit of extra bandwidth like you will with more switches.
Hope that helps.
P
Jason Short
Hi Paul,
That great news. Many thanks for the advice/assistance.
Regards,
Jason.
