Stacking 2x X670 with 40-60Gb traffic between
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hi all,
I'm looking to migrate a configuration where we have 2 separate X670-48 (not X670-V) into a stack.
We currently have a LAG of 40Gbps between the two switches which is routed
What is the recommended setup, and what is the procedure for migrating our working stand-alone setup into a stack?
We may also look at add an X650-24 to the same setup.
Hopefully I've framed my question correctly.
I have looked at the "Summit Family Switches Hardware Installation Guide". I gather I can use 4-6 ports on each switch to create the stack.
Switches are running the same XOS version, have same license levels.
Photo of jtessier
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,376 Points 5k badge 2x thumb
Hi Jason,
Here is an article which can point you to the appropriate section.
Further information on the port numbers are  available in the section "Summit X670 Stack Configuration Guidelines :"   in concepts guide.  (Page 135)
Adding a new node : information is available in the "Adding a Node to a Stack" section  (page 170)
I hope it helps...
Photo of jtessier
Thanks for the reply.
Can you use any 10G ports to create the stack, or just the alternate stacking ports? This isn't clear from the information, but I'm assuming so. Also I'm assuming that I would need to create a stack with enough ports to support the bandwidth that would be carried between the switches (backplane type).
What are the advantages to using the alternate stacking ports over regular ports?
Photo of Drew C.
Drew C., Community Manager
  • 36,016 Points 20k badge 2x thumb
Only the designated 10G alternate stack ports can be used.
Photo of jtessier
Ok, thanks for confirming.
As I mentioned, I have about 40Gbps of traffic between the switches. Other than giving me a single configuration point, stacking offer me much.
I'll still have to keep the LAG, and grow it as the traffic between switches grows.
