stacking 2x X670V with 2x VIM4-40G4X
  • Problem
  • Updated 4 years ago
  • Solved
i want to stacking 2x X670V with 2x VIM4-40G4X, how i can do this please? i read the config guide but it's not realy clear. i want to have 2 x 40GB satck ports on vim!
on my config, i do this:
switch 1:
configure stacking-support stack-ports 1 selection native V80
configure stacking-support stack-ports 2 selection native V80
enable stacking-suppo
reboot
Switch 2:
reboot
Switch 1:
enable stacking
yes
yes
in rear of my switch, i cable like this witch QSFP+ DAC
SW1--PS1 to SW2--PS2
SW1--PS2 to SW2--PS1
thank's for your help
Photo of CEFLOU
CEFLOU
  • 190 Points 100 badge 2x thumb
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
The Easy Setup procedure creates a stack with a master and a backup. The remaining nodes areconfigured with the master capability disabled. Easy Setup provides you an easy way to configure the
required stacking parameters for all nodes.
To avoid an additional stack reboot, we recommend that you configure the following stack related
features before invoking easy setup:
• Stacking license restriction
• SummitStack-V
• VIM3-40G4X port configuration
• VIM4-40G4X port configuration
• Enhanced protocol for MPLS support on a stack
The connectivity for stacking cable is different
Photo of CEFLOU
CEFLOU
thank's for your response.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,552 Points 10k badge 2x thumb
Don't use V80 in such a setup, you are wasting bandwidth. With 2 ports, you are doing V160.
