Stacking between x670-G2-48x-4q and x480-48t
  • Question
  • Updated 3 years ago
  • Answered
Which type of Connector + Cable type is needed to create an Alternate Stack between x670-G2-48x-4q and x480-48t?
Photo of MOLOY KUMAR KAR
MOLOY KUMAR KAR
  • 100 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Drew C.
Drew C., Community Manager
  • 40,724 Points 20k badge 2x thumb
Welcome to The Hub!
Do you have VIM module installed in the back of your X480?  Take a look at the Summary of Conditions for Alternate Stacking Ports for a better understanding of what is required for an alternate stack (aka SummitStackV).
Here's a matrix of what models and methods work together:
http://documentation.extremenetworks.com/summit/Summit_Family_HW_Install/Stacking/r_combining-switch...
As far as cabling, the QSFP+ direct-attach passive copper or the QSFP+ direct-attach active optical cables will be required, unless using SummitStackV, which will use a normal 10G fiber connection.  Native stacking with a VIM3-40G4x on the X480 would be preferred so that you can benefit from higher speeds and less risk of a bottleneck.
MOLOY KUMAR KAR
Hello,
Thanks!
As far as Native is concerned, my understanding is that x480 does not support that? Instead VIM3-40G4x is the Alternate Stacking/ also called SummitStack-V (that's what is mentioned in EXOS HW document, named Summit Family Hardware Installation Guide Table 105: Alternate Stacking Ports Page 215).
I am looking for SummitStack-V with VIM2-10G4X to stack x480-48t and x670-G2-48x-4q over 10Gbps.
Now x480 VIM2-10G4x has XFP ports whereas Summit X670-G2-48x-4q Alternate Stacking port uses 47 and 48 SFP+.
That means to use a 10Gbps Stack, we have to use XFP on x480, SFP+ on x670 and a normal MMF/LC-LC to connect the 2 Switches?
BR//Moloy
MOLOY KUMAR KAR
Also,
To add, x480 has this note so only VIM2-10G4x can be used on x480.
NOTE: The Summit X480-48t or X480-48x switch must have an installed VIM2-10G4X to configure alternate stacking ports. Alternate stacking ports are not supported with the VIM3-40G4X.
BR//Moloy
MOLOY KUMAR KAR
Below documentation says this:
  • Summit X480-48t and X480-48x switches do not have 10-Gbps ports on the base model switch. To use the SummitStack-V feature on these switches, you must install either a VIM2-10G4X module (ports S3 (51) and S4 (52) can then be configured as alternate stacking ports). Alternate stacking ports are not supported with the VIM3-40G4X.
http://documentation.extremenetworks.com/summit/Summit_Family_HW_Install/Stacking/c_summary-of-condi...
I am confused, can we use VIM3 or only VIM2 can be used for Stacking on a x480-48t?
Regards
Moloy
