Stacking cable support for X440-G2 (correction to documentation)
  • Article
  • Updated 7 months ago
In the Summit Hardware Installation Guide for EXOS 21, the "Stacking Cables" table is incorrect with respect to stacking-cable support on the X440-G2 switch.
http://documentation.extremenetworks.com/summit/Summit_Family_HW_Install/Stacking/r_stacking-cables....
At the bottom of the table, the stated limitation -- 10G stacking ports on ExtremeSwitching X440-G2 (48-port switches only), Summit X450-G2 10G, and ExtremeSwitching X620 switches -- should apply only to the 10 meter cable (model no. 10307). The shorter cable lengths (model nos. 10304, 10305, and 10306) are supported for all models of the X440-G2 as well as for the X450-G2 (10G models) and the X620.
I'll be sure to correct the table in the next update to the document.
Larry Kunz
Information Development
Extreme Networks
Photo of Larry Kunz
Larry Kunz, Employee
  • 1,304 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
I informed our team about this issue.
Hello All,
what is the reason for this limitation?
Thanks and regards
Ángel
