stacking problem in X670-G2
  • Question
  • Updated 1 year ago
  • Answered
Hi There
We have two X670G2-48x-4q and want to stack them to each other. we use V160 and easysetup according to following document. (EXOS version, License Level and Active Partition are same)
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-stack-with-Summit-X460-48p-a...
also connected ports according to following document:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-two-Summit-X670-switches-...
we encountered some problems. after enable stacking switches (some time one of switches) crashes and goes reboot.
some of logs listed here:
unconfigure dispatch attach fail: bcm_attach client unit 9
Unable to set ECMP hash= 0 for slotNo 2 unit 9, â 0 rc -19
<Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
<Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
<Erro:HAL.Card.Error> Slot-1: initBCMChipTempSensors : Failed to initialize chip temperature sensors for slot Slot-2
<Erro:HAL.Card.Error> Slot-1: ERROR4: attaching driver to slotNo 2 unit 0 remote 9, rc=-19
<Erro:HAL.Card.Error> Slot-1: Unable to set L2/L3 Hash = 5 for slotNo 2 unit 9, rc -19
default EXOS version is: 15.6
we cleared NVRAM, upgraded to EXOS 16.1.3.6-patch1-9 and 16.1.3.1-Patch1-7 but again not works (crash and reboot).
please tell us which EXOS is compatible with stacking and what we should do.
Regards.
Photo of omar khaled
omar khaled
  • 132 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,080 Points 5k badge 2x thumb
Hi.
it seems you already tested recommended firmware. I suggest to open ticket with GTAC. They will investigate what is wrong, what is the root cause.
Can be faulty device, can be unsupported tranceiver/cable...
Z.
omar khaled
thanks for your answer.
after some tests i found this devices doesn't work properly. for example in none-stack with default configuration  broadcasting doesn't work.
i should ask in another post.
Photo of Jason Parker
Jason Parker, Employee
  • 2,918 Points 2k badge 2x thumb
Do all of the switches contain all the same licenses
Have you tried building a stack with just with the.same image installed ( no configuration at all)
omar khaled
Hi Jason, thanks for your answer.
All of switches contain same lenience: Advanced Edge
I installed EXOS with same image and form Bootrom.
(it installed on primary and secondary partition)
with any configuration again occurs some errors.
Photo of Ram
Ram, Employee
  • 1,450 Points 1k badge 2x thumb
Could you please open a GTAC case? So we could analyze/troubleshoot further.
Photo of Chacko
Chacko
  • 1,206 Points 1k badge 2x thumb
Dear Omar,
is it right, that you use the 16.1.3.6 on the X670-G2?
I think only the new 21.X or higher is supported on that one.
Best Regards
Chacko
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,886 Points 10k badge 2x thumb
Hi Chacko,
EXOS 16.1 is currently recommended for the X670-G2 switches, but the new 21.x and 22.x versions can be used as well.
Please see http://www.extremenetworks.com/extreme-hardwaresoftware-compatibility-recommendation-matrices/softwa...
Erik
