Starting NMS - Java cache problem - Solution
  • Problem
  • Updated 3 years ago
  • Acknowledged
Some time ago i had problem starting Netsight because of java problem. Console fails loading cache. There was not easy thing to find where the cache was stored. [clearing java cache via java control panel was not effective].
Finally i found all three locations and wrote batch script to clear NMS java cache:
rmdir c:%homepath%\AppData\LocalLow\Sun\Java\Deployment\cache
rmdir c:%homepath%\Application Data\NetSight
rmdir c:%homepath%\AppData\Roaming\NetSight
Photo of Tomasz Lubas
Tomasz Lubas
  • 534 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Chris Sherman
Chris Sherman
  • 542 Points 500 badge 2x thumb
Thank you sir.
