Static BFD session not come UP vs Huawei ME60
  • Problem
  • Updated 5 months ago
Hi experts:
Hardware: Summit X670G2-48x-4q
ExtremeXOS version: 16.1.2.14
I hope you can help me in this little issue, I am trying to bring up a BFD session in a p2p link from my x670 Extreme Stack with a Huawei Router ME60 in the other side, I have currently a BGP session ESTABLISHED between them, but the BFD is not coming UP.
On both sides I'm trying to configure BFD protection to keep checked the remote loopback reached by a static route (loopbacks interfaces where the BGP session is created).
First of all I tried to match the timers on Tx/Rx and the Multiplier 50,50 (minimum allowed on extreme side) and 3 (multiplier) with no results.
After that we changed to 1000ms on Tx/Rx on extreme side, then to 13500ms, then changed back to 50 and changed the local Discriminator as 1 in both sides. No results.
In the log always I'm getting the following message:
<"Received BFD an invalid packet on VLAN XXXXXX Error:Invalid ttl value for single Hop session">
I tried to shutdown/no shut ports , What can be the issue now???????? suggestions?????
Here I share the output  and config from both nodes:
[ME60]***************************************************************************
Session MIndex : 16722     (Multi Hop) State : Down      Name : vpn_3
  Local Discriminator    : 8519             Remote Discriminator   : 0
  Session Detect Mode    : Asynchronous Mode Without Echo Function
  BFD Bind Type          : Peer IP Address
  Bind Session Type      : Static_Auto
  Bind Peer IP Address   : 172.31.50.74
  Bind Interface         : -
  Bind Source IP Address : 172.31.50.73
  Vpn Instance Name      : vpn_three
  FSM Board Id           : 1                TOS-EXP                : 7
  Min Tx Interval (ms)   : 50               Min Rx Interval (ms)   : 50
  Actual Tx Interval (ms): -                Actual Rx Interval (ms): -
  Local Detect Multi     : 3                Detect Interval (ms)   : -
  Echo Passive           : Disable          Acl Number             : -
  Destination Port       : 3784             TTL                    : 253
  Proc Interface Status  : Disable          Process PST            : Disable
  WTR Interval (ms)      : -
  Active Multi           : -                DSCP                   : -
  Last Local Diagnostic  : No Diagnostic
  Bind Application       : AUTO
  Session TX TmrID       : -                Session Detect TmrID   : -
  Session Init TmrID     : -                Session WTR TmrID      : -
  Session Echo Tx TmrID  : -
  PDT Index              : FSM-4 | RCV-E | IF-1000000 | TOKEN-0
  Session Description    : -
     Total UP/DOWN Session Number : 7/7
CONFIGURATION:
<UNDER SUBINTERFACE GIG 1/1/0.1324>
bfd vpn_3 bind peer-ip 172.31.50.74 vpn-instance vpn_three source-ip 172.31.50.73 auto
 min-tx-interval 50
 min-rx-interval 50
 commit
ip route-static vpn-instance vpn_three 172.31.249.118 255.255.255.255 172.31.50.74 track bfd-session vpn_3 description vpn_3
[x670]**************************************************************************************
* (vr vr-usr-fija-ext) Slot-1 SW_THREE.43 # show bfd session detail
Neighbor       : 172.31.50.73        Local       : 172.31.50.74
VR-Name        : vr-usr-fija-ext     Interface   : user-fija-bras2
Session Type   : Single Hop          State       : Down
Detect Time    : 0 ms                Age         : 0 ms
Discriminator (local/remote)    : 1 / 0
Demand Mode (local/remote)      : Off / Off
Poll (local/remote)             : Off / Off
Tx Interval (local/remote)      : 50 / 1 ms
Rx Interval (local/remote)      : 50 / 1 ms
oper Tx Interval                : 50 ms
oper Rx Interval                : 0 ms
Multiplier (local/remote)       : 3 / 3
Local Diag                      : 0 (No Diagnostic)
Remote Diag                     : 0 (No Diagnostic)
Authentication                  : None
Clients                         : STATIC
Uptime                          : 00 days 00 hours 00 minutes 00 seconds
Up Count                        : 0
Last Valid Packet Rx            : 00:00:00.0
Last Packet Tx                  : 15:49:15.307015
CONFIGURATION:
configure vlan user-fija-bras2 ipaddress 172.31.50.74 255.255.255.252
enable ipforwarding vlan user-fija-bras2
enable bfd vlan user-fija-bras2
configure bfd vlan user-fija-bras2 receive-interval 50 transmit-interval 50
enable iproute bfd 172.31.50.73 vr vr-usr-fija-ext
Please note that the Huawei router is under customer permises so I do not have the control to access this, each change I request is needed a customer intervention.
Thanks in advance for your thougts/suggestions.
Regards
Photo of Sergio Galvez
Sergio Galvez
  • 192 Points 100 badge 2x thumb
Posted 5 months ago
Be the first to post a reply!
