static nat on dhcp interface
  • Question
  • Updated 2 weeks ago
  • Answered
how do i configure a static outside nat on a dhcp interface like
'ip nat outside destination static 123.123.123.8 2222 tcp 10.10.10.10 22'
The ip 123.123.123.8 needs to be replaced with the dhcp adress.
I am using wing 5.8.6.
Thx for your help.
Best Regards
Markus
Photo of Starrag AG
Starrag AG
  • 80 Points 75 badge 2x thumb
Posted 3 weeks ago
Photo of Sukhdeep Singh Johar
Sukhdeep Singh Johar, Employee
  • 210 Points 100 badge 2x thumb
Markus,
You cannot use a DHCP in this case for the outside interface.
What is your use case ? You would not use DHCP in such a requirement.
regards,
Sukhdeep
Photo of Starrag AG
Starrag AG
Hi, my setup looks like this.
I want a to make a port-forwarding for reach services from the server (http,ssh,...) from the internet.
The IP from the Modem changes from time to time. So a static port forwarding on a fixed ip is not a solution.
Is there a way to make that, like other routers does?
Thx.
best regards
Markus
Thanks Markus. Got it.
But we currently support static option only.
regards,
sukhdeep
