Stay away from EXOS 22.2.1.5
  • Problem
  • Updated 1 year ago
  • Solved
Code 22.2.1.5 running on x460G2 has MAJOR stability issues with stacking.  I don't suggest running this code in production.
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Posted 1 year ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Official Response
Hi All,
Investigating this with our development team, we've narrowed it down to an issue with diffserv replacement and policy.
The quick explanation is that when both diffserv examination and policy are enabled, some ACLs get corrupted that can lead to a process crash on non-master nodes in a stack. A workaround on 22.2 would be to disable diffserv replacement. A fix is scoped for 22.3.
See the following GTAC Knowledge article for more information:
https://gtacknowledge.extremenetworks.com/articles/Solution/tBcmxSync-process-crash-with-Policy-and-...
