STP configuration for vmware ESXi
  • Question
  • Updated 2 years ago
  • Answered
We have 2x BD8810's in an MLAG configuration, each with connections to VMWare ESXi 5.5 hosts.
Each port to the ESXi host is tagged for multiple VLANs.
What is the correct/recommended spanning tree configuration in this scenario?
I've trawled the forum and the suggestions seem to be to use PVST which I don't want to do as it is Cisco proprietary and there are no Cisco switches. The other suggestion was to configure it as point-to-point which also didn't make sense to me as that is more for uplinks to other switches were BPDU's will be transmitted (not the case with VMWare).
Keen to get the recommended approach and thoughts.
Thanks!
Shannon
Photo of Shannon Rowe
Shannon Rowe
  • 122 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,854 Points 5k badge 2x thumb
Hi.
First why stp at all? You should not have redundand links you want to block in this case so I would use ELRP just for loop detection.
If you need stp, I would use standard MSTP as it is understood by every vendor.
Z.
Shannon Rowe
Thanks for that - yes absolutely that is a valid point, we could simple remove STP from the ports altogether.
Thanks,
Shannon
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
I suggest using ELRP, especially in a ToR situation where you have servers connected.  Why deal with slow STP when ELRP is so much faster?!  Sure, STP has it's functionality and use, but to connect redundant links, I don't think STP is needed at all.  The only place I run STP is on the two uplink ports I have in a LAG (sharing).  That way, if the LAG breaks or LACP-DU don't make it to their destinations, STP will block a link and prevent a loop.
The way I have ELRP setup is... create a "carrier" vlan
If you need help configuring ELRP over an MLAG let me know.
Photo of Jeremy
Jeremy, Embassador
DC-X670V-R4-SW1.1 # show configuration "elrp"
# Module elrp configuration.
enable elrp-client
configure elrp-client periodic UC_ELRP ports all interval 1 log disable-port ingress duration 300
configure elrp-client disable-port exclude 48
configure elrp-client disable-port exclude 57
configure elrp-client disable-port exclude 58
configure elrp-client disable-port exclude 59
configure elrp-client disable-port exclude 60
configure elrp-client disable-port exclude 62
DC-X670V-R4-SW1.2 #
Just configure the ELRP vlan and tag it on all ports except the uplink ports.  Exclude the uplink and ISC ports from the elrp-client periodic poll.
Shannon Rowe
Brilliant thanks for that Jeremy, I'll also consider ELRP.
I guess I shy away from it a little bit as it is Extreme proprietary and if management ever decide to move away from Extreme switching for another vendor it would make the transition that much harder. Sticking with industry open standards is a "safer" option.
Agree it is proprietary. But why not use it as we support standards also. When you chose to buy 3rd party device and integrate it, you will need to reconfigure the box anyway => why not benefit from ELRP now as it gives you better benefits. You can revert to mstp anytime...
I hope you will like XOS (and Extreme) so much, you will not consider other technology in the future => you can benefit from ELRP in the future also :)
Z.
