STP errors
  • Question
  • Updated 3 years ago
The following error is filling up the logs. Port 1:45 is the uplink port to another extreme switch. I am unable to find a solution for this. Need assistance.
<Erro:STP.InBPDU.Drop> Slot-1: Port=1:45: No associated STP port for STP Domain tag 10 (Rate-limited)
I can share more details if needed.
Photo of Jeevan
Jeevan
  • 100 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Jeevan
It looks as if the switch is receiving a STP BPDU fro the uplink port.  Is the switch that it is connected to running STP?
Thanks
P
Photo of Jeevan
Jeevan
Yes, both this switch and the neighbor are running STP.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Jeevan,
Since both of these switches are running STP, most likely there is a mismatch in the carrier vlan configured for the spanning tree domain. Is the switch on the other end seeing a similar log message?
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
Mostly happens due to mismatch in stp configuration .
easiest way is to capture the bpdu packet and see why there is a mismatch
and then fix it.[please use TCPdump or do port mirroring]
sometimes if we receive a bpdu from 3rd party switches cisco [pvst].
its a bpdu which is not understood by extreme so we get the error.
Note : pvst+ is understood by extreme if we have the extreme switch configured for pvst+
Photo of Jeevan
Jeevan
Can you point me to a doc which explains configuring extreme switch for pvst+ ?
Per VLAN Spanning TreeSwitching products that implement Per VLAN Spanning Tree (PVST) have been in existence for many
years and are widely deployed.
To support STP configurations that use PVST, ExtremeXOS has an operational mode called PVST+.
In this document, PVST and PVST+ are used interchangeably. PVST+ is an enhanced version
of PVST that is interoperable with 802.1Q STP. The following discussions are in regard to
PVST+, if not specifically mentioned.
Extreme Exos concepts guide 15.6
Please refer page 1069
Photo of Jeevan
Jeevan
I tried adding a tag for STP Domain and i get the following error:
Error: Please configure a stpd dot1q tag first
Is there an example i can follow to configure stp for a cisco extreme networks mixed environment ?
M6:U38
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-50
configure vr VR-Default add ports 1-50
create vlan "data"
configure vlan data tag 20
create vlan "test"
configure vlan test tag 10
create vlan "unatagg"
configure vlan unatagg tag 50
configure ports 49 auto off speed 10000 duplex full
configure ports 50 auto off speed 10000 duplex full
configure vlan data add ports 1-2 tagged
configure vlan Default add ports 1-50 untagged
configure vlan test add ports 1-2 tagged
configure vr VR-Default delete protocol mpls
# Module stp configuration.
configure mstp region 0004968255cf
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
create stpd s1
create stpd s2
enable stpd s0 auto-bind vlan Default
configure stpd s0 add vlan Default ports 1 pvst-plus
configure stpd s1 add vlan test ports 1 emistp
configure stpd s2 add vlan data ports 1 emistp
configure stpd s0 add vlan Default ports 2 dot1d
configure stpd s1 add vlan test ports 2 pvst-plus
configure stpd s2 add vlan data ports 2 pvst-plus
configure stpd s0 tag 1
configure stpd s1 tag 10
enable stpd s1
configure stpd s2 tag 20
enable stpd s2
M7:U37
configure vr VR-Default delete ports 1-12
configure vr VR-Default add ports 1-12
create vlan "data"
create vlan "test"
configure vlan Default add ports 1-12 untagged
configure mstp region 000496839c40
create stpd s1
create stpd s2
configure stpd s2 priority 1
enable stpd s1
enable stpd s2
K7:U32(3550)
spanning-tree mode pvst
spanning-tree extend system-id
vlan 10,20-21
vlan 50
name UNTAGGED
vlan 200
interface FastEthernet0/1
switchport trunk encapsulation dot1q
switchport mode trunk
interface FastEthernet0/2
K7:U33:
interface GigabitEthernet3/0/2
no shutdown
interface GigabitEthernet3/0/3
no shutdown
vlan 10,20-21
Photo of M.Nees
M.Nees, Embassador
  • 9,126 Points 5k badge 2x thumb
i see the same error when neighbour switch is a enterasys b5. It seem because enterasys RSTP / BPDU have no vlan association, X440 printed this error to all non carrier (tagged) VLANs on that interswitch link!
Does anybody know how i can avoid this messages?
