stp running in vlan
  • Question
  • Updated 2 years ago
  • Answered
i m creating  14 vlan in summit X440,so i want to run stp in vlan... can i run individual stp in all 14 vlan or can i run only one stp for all vlan... plz suggest and help me,r also give me code of stp configuration......
Photo of zain mallick
zain mallick
  • 318 Points 250 badge 2x thumb
Posted 2 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
Use elrp and make your life simple.
Create a vlan just for elrp, we use "no-loop" add it tagged on all ports and configure elrp to run on that vlan.
If this simple solution is appealing I'm sure one of us can get you the one or two commands you will need to configure it.
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,016 Points 5k badge 2x thumb
David beat me to it... Best way to configure STP is to not run STP ... ELRP will provide the loop protection for the edge and if you have multiple uplinks you can use EAPS.
zain mallick
but sir eaps is runnibg on 2 or more switches,but i have only one switch summit X440 ,and apply multiple vlan in one switch r want to run stp in all vlan...? what can i doo...? how to apply elrp in vlan plz give some advise r some codes plz...
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
