STP topology and configuration steps
  • Question
  • Updated 3 years ago
  • Answered
I am new to this xtereme switch so am in a situation to configure stp. I have to setup STP in two X650-24x(SSns), so if anyone share me a topology to setup STP and configuration steps it will be a great helpful.
Photo of Dinesh Kumar
Dinesh Kumar
  • 130 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
Hi Dinesh,
This GTAC Knowledge article may be helpful:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-RSTP-in-EXOS
-Brandon
(Edited)
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hi Dinesh,
As mentioned in the other post we need something a little more specific to help you. Do you have a network already setup? are you starting from scratch? Did the resources I linked in the other post help?
Dinesh Kumar
Hi Voss,
I am starting from the scratch, I am doing a lab setup configuring rstp in two switch. So I need the step by step configuration for the two switch with a simple topology diagram.
Dinesh Kumar
    |------------|port4    port4 |-----------|
    | switch1 |------------------| switch2|
    |------------|port5    port5 |-----------|
Configuration for this setup
Patrick Voss, Alum
Hi Dinesh,
Based on this information the article Brandon and I linked has everything you need. You will just need to fill in the VLAN and port information into the commands.
Dinesh Kumar
OK Voss. Thanks.
