Stpd disabled port
  • Question
  • Updated 1 year ago
  • Answered
I have two ports on my switch disable by STPD.
Stpd: s0                Stp: ENABLED            Number of Ports: 50Rapid Root Failover: Disabled
Operational Mode: 802.1W                        Default Binding Mode: 802.1D
802.1Q Tag: (none)
Ports: 1:1,1:2*,1:4,1:5,1:6,1:7,1:8,1:9,1:10,1:11,
       1:12,1:13,1:14,1:15,1:16,1:17,1:18,1:19,1:20,1:21,
       1:22,1:23,1:24,1:25,1:26,1:27,1:28,1:29,1:30,1:31,
       1:32,1:33,1:34,1:35,1:36,1:37,1:38,1:39,1:40,1:41,
       1:42,1:43,1:44,1:45,1:46,1:47*,1:49,1:50,1:51,1:52
the ports in question are 1:2, 1:47 how can i enable de port again?
Photo of GONÇALO NUNO CONTENTE PIMENTEL DA SILVA REIS
Posted 1 year ago
Photo of Daniel B
Daniel B
  • 360 Points 250 badge 2x thumb
hi,
on my summits I have blocked ports too, but not marked with a *.
Can you post the output of "show stpd "s0" detail" ?
Regards Daniel
Hi, here it is.
802.1Q Tag: (none)
Participating Vlans: Default,Docencia,KK,LABS,SNMP_Vlan
Auto-bind Vlans: Administrativa-C,Aulas,DAPs,Default,Docencia,
                     KK,LAB01,LAB02,LAB03,LAB04,
                     LAB05,LAB06,LAB07,LAB08,LAB09,
                     LAB10,LAB11,LAB12,LAB13,LABS,
                     Seguridad,SNMP_Vlan,VOIP-ACCESS
Bridge Priority            : 32768
Operational Bridge Priority: 32768
BridgeID                   : 80:00:02:04:96:9b:38:43
Designated root            : 20:00:64:f6:9d:bc:74:00
RootPathCost: 40000     Root Port     : 1:49
MaxAge      : 20s       HelloTime     : 2s      ForwardDelay     : 15s
CfgBrMaxAge : 20s       CfgBrHelloTime: 2s      CfgBrForwardDelay: 15s
Topology Change Time           : 35s            Hold time        : 1s
Topology Change Detected       : FALSE          Topology Change  : FALSE
Number of Topology Changes     : 0
Time Since Last Topology Change: 0s
Topology Change initiated locally on Port 1:49
Topology Change last received on Port 1:49 from 00:11:88:31:f2:94
Backup Root               : Off         Backup Root Activated  : FALSE
Loop Protect Event Window : 180s        Loop Protect Threshold : 3
New Root Trap             : On          Topology Change Trap   : Off
Tx Hold Count             : 6
Participating VLANs:
VLAN                                     Tag    Number of Ports
          Ports
Default                                  1      9
          1:42(D),1:43(D),1:44(D),1:45(D),1:46(D),1:49(F),1:50(D),1:51(D),
          1:52(D)
DD                                 100    1
          1:47*(D)
KK                                       1250   2
          1:1(D),1:2*(D)
CC                                     425    37
          1:5(D),1:6(D),1:7(D),1:8(D),1:9(D),1:10(D),1:11(D),1:12(D),
          1:13(D),1:14(D),1:15(D),1:16(D),1:17(D),1:18(D),1:19(D),1:20(D),
          1:21(D),1:22(D),1:23(D),1:24(D),1:25(D),1:26(D),1:27(D),1:28(D),
          1:29(D),1:30(D),1:31(D),1:32(D),1:33(D),1:34(D),1:35(D),1:36(D),
          1:37(D),1:38(D),1:39(D),1:40(D),1:41(D)
AA                                1000   3
          1:4(D),1:49(F),1:50(D)
Flags: B-Blocking, D-Disabled, F-Forwarding, I-Listening, L-Learning
Photo of Daniel B
Daniel B
You use a port sharing with the Ports 2,3,47 and 48 ?!
The Ports are not blocked by STP but disabled.
Can you "enable ports 1:2" and "enable ports 1:47" ?
Hi, after checking the configuration i found out that the ports marked with * belong to a Lacp.
