Summit 24p SNMP OID for extremeEdpNeighborId vanished please help
  • Problem
  • Updated 3 years ago
  • Solved
OID for extremeEdpNeighborId has vanished from the ExtremeEdpEntry table
out put from snmpwalk..
snmpwalk -v2c -c public 172.16.98.4 1.3.6.1.4.1.1916.1.13.2.1.2
EXTREME-EDP-MIB::extremeEdpNeighborId = No Such Object available on this agent at this OID
I have checked on multiple switches that have been on line for varying numbers of days and are on totally different firmwares but they all behave this way so I am ruling out firmware and needing a reboot unless the vanishing happens moreless on or shortly after its booting up
any further advise would be very much appreciated
thanks
Photo of Jon Doe
Jon Doe
  • 72 Points
Posted 3 years ago
Photo of Dorian Perry
Dorian Perry, Employee
  • 2,302 Points 2k badge 2x thumb
Hi Jon,
Which application is being used to perform these SNMP walks?
Was there previously a response for this OID when polled in the same way previously?
Were there any changes to the SNMP App configuration or the Switch configuration?
Photo of Alexandr P
Alexandr P, Embassador
  • 12,742 Points 10k badge 2x thumb
Hi, Jon!
First of all you have to look at ConceptGuide - is there ExtremeEdpEntry.
In EXOS_ConceptGuide for 15.4 there is only extremeEdpTable, extremeEdpNeighborTable and extremeEdpPortTable.
In MIB file there is a lot MIBs from ExtremeWare, so they didn't work in EXOS.
Thank you!
