Summit exos Vlanning help please.
  • Question
  • Updated 3 years ago
  • Answered
Im trying to force one vlan down the wan port without being able to see the other vlans.
Currently all vlans have inter-vlan routing turned on to use the wan port for traffic going to the firewall.
I need to add a new vlan that can use the wan port for outbound traffic, but may not talk to the other vlans currently there.
Anyone have tips on this ? Getting another drop for just this vlan is out of the question. I need to use the wan fiber to the firewall.
Photo of Joe Belliveau
Joe Belliveau
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,484 Points 10k badge 2x thumb
You should be able to make this VLAN strictly L2 and have the firewall as the gateway. This way any traffic outside of its subnet will be sent directly to the firewall. The firewall will need this VLAN configured on its side as well.
Joe Belliveau
thanks I will see if i can figure out those commands !
