Summit x350-48t reset to default
  • Problem
  • Updated 1 year ago
  • Solved
Hi all! I bought a Summit X350-48t switch off of ebay and when I went to the terminal in puTTy and I put in the default login and it said that it was incorrect and I tried this several times. How do I reset the switch to factory defaults?
version:1.0.3.5
Photo of hoeper
hoeper
  • 122 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,404 Points 2k badge 2x thumb
Nick Yakimenko
did you try 'h' for help?
Photo of hoeper
hoeper
yes
Photo of hoeper
hoeper
But still no luck
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,418 Points 3k badge 2x thumb
type boot, hit enter, then hold space again at the prompt. The 350 has a bootstrap and a bootrom. bootrom is where you enter the "config none" command
Photo of hoeper
hoeper
Thank You!
