Summit X440 Configuration Questions/Help
  • Problem
  • Updated 4 years ago
Long and probably confusing post.  Please let me know if clarification is needed.
I have several Summit X440 switches in a ring configuration.  The actual backbone between the switches is a combination of dark fiber, microwave, and Metro-E.  At two of my microwave sites I have microwave spurs to sites no in the ring.  These spur sites also have X440's.  At site A there is a  LAN that is separate from the WAN.  The WAN ring is running Layer 2 with 5 or 6 VLANS being protected via ERPS.  I added VLAN 3010 in the site A X440 and the X440 at the spur site (Site B) I also added VLAN 3010.  VLAN 3010 is tagged on the ports that the microwave is connected to and port 10 on each switch is added to VLAN 3010 untagged. At site A, I configured a Cisco switch port as a router port and connected it to port 10 of the X440.  At site B I configured an HP Procurve similarly and connected it to switch port 10.  All works great and traffic passes between the switches as it should.
At site C, I have a similar configuration with a few minor differences.  On the X440's at Site C and D, I used VLAN 3011.  The local LAN switches are both Cisco in this case.  This link does not work... sort of.
With the Cisco plugged into port 10, I can not ping or access any device at Site D.  If I unplug the Cisco switch from the X440 at Site C and plug a laptop in, I can access any device at Site D.  If I go to Site D and unplug the Cisco and put a laptop in its' place, I cannot access any devices at Site C.
As a sanity check, I pulled the Cisco from Site D and took it to Site C and connected them with a crossover cable  and everything operates as it should.  I feel like it is an issue with the X440 at site C but honestly, I know way more about Cisco than I do Extreme stuff so I am a little lost.
The X440 switches at Sites A and C are connected via Microwave.
The Cisco switches at Sites A and C are on the same LAN connected via another microwave link.  At first I thought that maybe I created a loop and Spanning-Tree killed the port but I unplugged the cable between the X440 and Cisco at Site A and still no-go.
If the topology is confusing, I can provide a diagram.
Here is the config from Site C:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.12.02 11:58:37 =~=~=~=~=~=~=~=~=~=~=~=
sh conf
# Module devmgr configuration.
configure snmp sysName "Site_C_GSS_1"
configure snmp sysLocation " Site_C"
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-24
configure vr VR-Default add ports 1-24
configure vlan default delete ports 1-24
create qosprofile "QP2"
create qosprofile "QP3"
create qosprofile "QP4"
create qosprofile "QP5"
create qosprofile "QP6"
create vlan "eaps_control1"
configure vlan eaps_control1 tag 901
configure vlan eaps_control1 qosprofile QP8
create vlan "nm_220"
configure vlan nm_220 tag 220
configure vlan nm_220 qosprofile QP6
create vlan "nm_519"
configure vlan nm_519 tag 519
configure vlan nm_519 qosprofile QP6
create vlan "nm_820"
configure vlan nm_820 tag 820
create vlan "nm_45"
configure vlan nm_45 tag 45
configure vlan nm_45 qosprofile QP6
create vlan "nm_3011"
configure vlan nm_3011 tag 3011
configure vlan nm_3011 qosprofile QP2
create vlan "nm_66"
configure vlan nm_66 tag 40
configure vlan nm_66 qosprofile QP5
create vlan "Subring_3"
configure vlan Subring_3 tag 309
enable diffserv examination port 1
enable diffserv examination port 2
enable diffserv examination port 3
enable diffserv examination port 4
enable diffserv examination port 5
configure ports 5 auto off speed 100 duplex full
enable diffserv examination port 6
enable diffserv examination port 7
enable diffserv examination port 8
enable diffserv examination port 9
enable diffserv examination port 10
enable diffserv examination port 11
enable diffserv examination port 12
enable diffserv examination port 13
enable diffserv examination port 14
enable diffserv examination port 15
enable diffserv examination port 16
enable diffserv examination port 17
enable diffserv examination port 18
enable diffserv examination port 19
configure ports 19 auto off speed 100 duplex full
enable diffserv examination port 20
enable diffserv examination port 21
configure ports 21 medium copper auto off speed 100 duplex full
enable diffserv examination port 22
configure ports 22 medium fiber auto off speed 1000 duplex full
enable diffserv examination port 23
enable diffserv examination port 24
configure ports 24 medium copper auto off speed 100 duplex full
configure ports 24 medium fiber auto off speed 1000 duplex full
configure vlan eaps_control1 add ports 23 tagged
configure vlan nm_220 add ports 19, 21-24 tagged
configure vlan nm_519 add ports 13, 17-19, 21-24 tagged
configure vlan nm_519 add ports 14 untagged
configure vlan nm_820 add ports 19, 21-24 tagged
configure vlan nm_45 add ports 21-24 tagged
configure vlan nm_3011 add ports 17-18 tagged
configure vlan nm_3011 add ports 10 untagged
configure vlan nm_66 add ports 1-4, 17-19, 21-24 tagged
configure vlan nm_66 add ports 5-6 untagged
configure vlan Subring_3 add ports 22, 24 tagged
configure vlan Mgmt ipaddress xxx.xxx.xxx.10 255.255.255.0
configure vlan nm_66 ipaddress xxx.xx.xxx.16 255.255.252.0
configure qosprofile QP2 maxbuffer 100 weight 1
configure qosprofile QP3 maxbuffer 100 weight 1
configure qosprofile QP4 maxbuffer 100 weight 1
configure qosprofile QP5 maxbuffer 100 weight 1
configure qosprofile QP6 maxbuffer 100 weight 1
configure qosprofile QP2 minbw 0 maxbw 100 ports 1
configure qosprofile QP3 minbw 0 maxbw 100 ports 1
configure qosprofile QP4 minbw 0 maxbw 100 ports 1
configure qosprofile QP5 minbw 0 maxbw 100 ports 1
configure qosprofile QP6 minbw 0 maxbw 100 ports 1
configure qosprofile QP2 minbw 0 maxbw 100 ports 2
configure qosprofile QP3 minbw 0 maxbw 100 ports 2
configure qosprofile QP4 minbw 0 maxbw 100 ports 2
configure qosprofile QP5 minbw 0 maxbw 100 ports 2
configure qosprofile QP6 minbw 0 maxbw 100 ports 2
configure qosprofile QP2 minbw 0 maxbw 100 ports 3
configure qosprofile QP3 minbw 0 maxbw 100 ports 3
configure qosprofile QP4 minbw 0 maxbw 100 ports 3
configure qosprofile QP5 minbw 0 maxbw 100 ports 3
configure qosprofile QP6 minbw 0 maxbw 100 ports 3
configure qosprofile QP2 minbw 0 maxbw 100 ports 4
configure qosprofile QP3 minbw 0 maxbw 100 ports 4
configure qosprofile QP4 minbw 0 maxbw 100 ports 4
configure qosprofile QP5 minbw 0 maxbw 100 ports 4
configure qosprofile QP6 minbw 0 maxbw 100 ports 4
configure qosprofile QP2 minbw 0 maxbw 100 ports 5
configure qosprofile QP3 minbw 0 maxbw 100 ports 5
configure qosprofile QP4 minbw 0 maxbw 100 ports 5
configure qosprofile QP5 minbw 0 maxbw 100 ports 5
configure qosprofile QP6 minbw 0 maxbw 100 ports 5
configure qosprofile QP2 minbw 0 maxbw 100 ports 6
configure qosprofile QP3 minbw 0 maxbw 100 ports 6
configure qosprofile QP4 minbw 0 maxbw 100 ports 6
configure qosprofile QP5 minbw 0 maxbw 100 ports 6
configure qosprofile QP6 minbw 0 maxbw 100 ports 6
configure qosprofile QP2 minbw 0 maxbw 100 ports 7
configure qosprofile QP3 minbw 0 maxbw 100 ports 7
configure qosprofile QP4 minbw 0 maxbw 100 ports 7
configure qosprofile QP5 minbw 0 maxbw 100 ports 7
configure qosprofile QP6 minbw 0 maxbw 100 ports 7
configure qosprofile QP2 minbw 0 maxbw 100 ports 8
configure qosprofile QP3 minbw 0 maxbw 100 ports 8
configure qosprofile QP4 minbw 0 maxbw 100 ports 8
configure qosprofile QP5 minbw 0 maxbw 100 ports 8
configure qosprofile QP6 minbw 0 maxbw 100 ports 8
configure qosprofile QP2 minbw 0 maxbw 100 ports 9
configure qosprofile QP3 minbw 0 maxbw 100 ports 9
configure qosprofile QP4 minbw 0 maxbw 100 ports 9
configure qosprofile QP5 minbw 0 maxbw 100 ports 9
configure qosprofile QP6 minbw 0 maxbw 100 ports 9
configure qosprofile QP2 minbw 0 maxbw 100 ports 10
configure qosprofile QP3 minbw 0 maxbw 100 ports 10
configure qosprofile QP4 minbw 0 maxbw 100 ports 10
configure qosprofile QP5 minbw 0 maxbw 100 ports 10
configure qosprofile QP6 minbw 0 maxbw 100 ports 10
configure qosprofile QP2 minbw 0 maxbw 100 ports 11
configure qosprofile QP3 minbw 0 maxbw 100 ports 11
configure qosprofile QP4 minbw 0 maxbw 100 ports 11
configure qosprofile QP5 minbw 0 maxbw 100 ports 11
configure qosprofile QP6 minbw 0 maxbw 100 ports 11
configure qosprofile QP2 minbw 0 maxbw 100 ports 12
configure qosprofile QP3 minbw 0 maxbw 100 ports 12
configure qosprofile QP4 minbw 0 maxbw 100 ports 12
configure qosprofile QP5 minbw 0 maxbw 100 ports 12
configure qosprofile QP6 minbw 0 maxbw 100 ports 12
configure qosprofile QP2 minbw 0 maxbw 100 ports 13
configure qosprofile QP3 minbw 0 maxbw 100 ports 13
configure qosprofile QP4 minbw 0 maxbw 100 ports 13
configure qosprofile QP5 minbw 0 maxbw 100 ports 13
configure qosprofile QP6 minbw 0 maxbw 100 ports 13
configure qosprofile QP2 minbw 0 maxbw 100 ports 14
configure qosprofile QP3 minbw 0 maxbw 100 ports 14
configure qosprofile QP4 minbw 0 maxbw 100 ports 14
configure qosprofile QP5 minbw 0 maxbw 100 ports 14
configure qosprofile QP6 minbw 0 maxbw 100 ports 14
configure qosprofile QP2 minbw 0 maxbw 100 ports 15
configure qosprofile QP3 minbw 0 maxbw 100 ports 15
configure qosprofile QP4 minbw 0 maxbw 100 ports 15
configure qosprofile QP5 minbw 0 maxbw 100 ports 15
configure qosprofile QP6 minbw 0 maxbw 100 ports 15
configure qosprofile QP2 minbw 0 maxbw 100 ports 16
configure qosprofile QP3 minbw 0 maxbw 100 ports 16
configure qosprofile QP4 minbw 0 maxbw 100 ports 16
configure qosprofile QP5 minbw 0 maxbw 100 ports 16
configure qosprofile QP6 minbw 0 maxbw 100 ports 16
configure qosprofile QP2 minbw 0 maxbw 100 ports 17
configure qosprofile QP3 minbw 0 maxbw 100 ports 17
configure qosprofile QP4 minbw 0 maxbw 100 ports 17
configure qosprofile QP5 minbw 0 maxbw 100 ports 17
configure qosprofile QP6 minbw 0 maxbw 100 ports 17
configure qosprofile QP2 minbw 0 maxbw 100 ports 18
configure qosprofile QP3 minbw 0 maxbw 100 ports 18
configure qosprofile QP4 minbw 0 maxbw 100 ports 18
configure qosprofile QP5 minbw 0 maxbw 100 ports 18
configure qosprofile QP6 minbw 0 maxbw 100 ports 18
configure qosprofile QP2 minbw 0 maxbw 100 ports 19
configure qosprofile QP3 minbw 0 maxbw 100 ports 19
configure qosprofile QP4 minbw 0 maxbw 100 ports 19
configure qosprofile QP5 minbw 0 maxbw 100 ports 19
configure qosprofile QP6 minbw 0 maxbw 100 ports 19
configure qosprofile QP2 minbw 0 maxbw 100 ports 20
configure qosprofile QP3 minbw 0 maxbw 100 ports 20
configure qosprofile QP4 minbw 0 maxbw 100 ports 20
configure qosprofile QP5 minbw 0 maxbw 100 ports 20
configure qosprofile QP6 minbw 0 maxbw 100 ports 20
configure qosprofile QP2 minbw 0 maxbw 100 ports 21
configure qosprofile QP3 minbw 0 maxbw 100 ports 21
configure qosprofile QP4 minbw 0 maxbw 100 ports 21
configure qosprofile QP5 minbw 0 maxbw 100 ports 21
configure qosprofile QP6 minbw 0 maxbw 100 ports 21
configure qosprofile QP2 minbw 0 maxbw 100 ports 22
configure qosprofile QP3 minbw 0 maxbw 100 ports 22
configure qosprofile QP4 minbw 0 maxbw 100 ports 22
configure qosprofile QP5 minbw 0 maxbw 100 ports 22
configure qosprofile QP6 minbw 0 maxbw 100 ports 22
configure qosprofile QP2 minbw 0 maxbw 100 ports 23
configure qosprofile QP3 minbw 0 maxbw 100 ports 23
configure qosprofile QP4 minbw 0 maxbw 100 ports 23
configure qosprofile QP5 minbw 0 maxbw 100 ports 23
configure qosprofile QP6 minbw 0 maxbw 100 ports 23
configure qosprofile QP2 minbw 0 maxbw 100 ports 24
configure qosprofile QP3 minbw 0 maxbw 100 ports 24
configure qosprofile QP4 minbw 0 maxbw 100 ports 24
configure qosprofile QP5 minbw 0 maxbw 100 ports 24
configure qosprofile QP6 minbw 0 maxbw 100 ports 24
# Module fdb configuration.
configure iparp vr VR-Default max_entries 4096
configure neighbor-discovery vr VR-Default timeout 10
configure neighbor-discovery vr VR-Mgmt timeout 10
# Module rtmgr configuration.
configure iproute add default xxx.xxx.xxx.254 vr VR-Mgmt
configure iproute add default xxx.xxx.yyy.254
# Module mcmgr configuration.
# Module aaa configuration.
create account AAAAA FFFF encrypted "xxxxxxxxxxxxxxxxxxxxxxxxx"
# Module acl configuration.
configure access-list zone SYSTEM application NetLogin application-priority 3
configure access-list zone SYSTEM application FIPSnooping application-priority 4
configure access-list zone SYSTEM application HealthCheckLAG application-priority 5
configure access-list zone SYSTEM application IdentityManager application-priority 6
configure access-list zone SYSTEM application VMTracking application-priority 7
configure access-list zone SYSTEM application PolicyManager application-priority 8
configure access-list zone SYSTEM application Snmp application-priority 11
configure access-list zone SYSTEM application Telnet application-priority 12
configure access-list zone SYSTEM application Http application-priority 13
configure access-list zone SYSTEM application Ssh2 application-priority 14
# Module bfd configuration.
# Module ces configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
# Module edp configuration.
# Module elrp configuration.
# Module ems configuration.
# Module epm configuration.
enable cpu-monitoring interval 20
# Module erps configuration.
enable erps
create erps subring3
configure erps subring3 add control vlan Subring_3
configure erps subring3 ring-port east 22
configure erps subring3 ring-port west 24
configure erps subring3 protection-port 24
configure erps subring3 timer wait-to-restore 5000
configure erps subring3 cfm md-level 3
configure erps subring3 cfm port east ccm-interval 100
configure erps subring3 cfm port east mepid 3222 remote-mepid 1722
configure erps subring3 cfm port west ccm-interval 100
configure erps subring3 cfm port west mepid 3224 remote-mepid 3124
enable erps subring3
configure erps subring3 add protected vlan nm_45
configure erps subring3 add protected vlan nm_66
configure erps subring3 add protected vlan nm_220
configure erps subring3 add protected vlan nm_519
configure erps subring3 add protected vlan nm_820
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lldp configuration.
# Module mrp configuration.
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
configure sntp-client primary xxx.xx.xxx.88 vr VR-Default
configure sntp-client secondary xxx.xx.xxx.89 vr VR-Default
enable sntp-client
# Module poe configuration.
# Module rip configuration.
# Module ripng configuration.
# Module snmpMaster configuration.
configure snmpv3 add target-addr v1v2cNotifyTAddr1 param v1v2cNotifyParam1 ipaddress xxx.xx.xxx.20 transport-port 162 tag-list defaultNotify
configure snmpv3 add target-params v1v2cNotifyParam1 user v1v2cNotifyUser1 mp-model snmpv2c sec-model snmpv2c sec-level noauth
# Module stp configuration.
configure mstp region 00049636f7f9
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
enable stpd s0 auto-bind vlan Default
# Module synce configuration.
# Module telnetd configuration.
# Module tftpd configuration.
# Module thttpd configuration.
# Module vmt configuration.
# Module vsm configuration.
Here is the config from Site D:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.10.28 11:34:39 =~=~=~=~=~=~=~=~=~=~=~=
# sh conf
configure snmp sysName "Site_D_GSS_1"
configure snmp sysLocation " Site_D"
create vlan "nm_66"
configure vlan nm_66 tag 66
configure vlan eaps_control1 add ports 21-24 tagged
configure vlan nm_519 add ports 13, 19, 21-24 tagged
configure vlan nm_3011 add ports 21-23 tagged
configure vlan nm_66 add ports 1-3, 19, 21-24 tagged
configure vlan nm_66 add ports 5 untagged
configure vlan Mgmt ipaddress xxx.xxx.xxx.13 255.255.255.0
configure vlan nm_66 ipaddress xx.xxx.xxx.19 255.255.252.0
create account AAAAA FFF encrypted "xxxxxxxxxxxxxxxxxxxxxxx"
enable sntp-client
Photo of Jamey Wright
Jamey Wright
  • 70 Points
Posted 4 years ago
Be the first to post a reply!
