Summit X440 Swtich performance monitoring
  • Question
  • Updated 3 years ago
  • Answered
So what's the best method to monitor my Summit Stack switch performance.  I think we might have an issue with congestion.  I have one switch mostly open at the moment so I can definitely redistributed the LAN connections but would like to be able to monitor the before and after.  The XOS port stats option just does not seem to be the way to go on that. Is there another option I can use?
Photo of Joe
  • 430 Points 250 badge 2x thumb
Posted 3 years ago
Photo of aTomo
  • 140 Points 100 badge 2x thumb
I think you will get what you need if you run the commands
show ports congestion no-refresh
show ports utilization bandwidth
Before and after...
