Summit x460 syslog configuration help
  • Question
  • Updated 11 months ago
  • Answered
Hello all, I need assistance configuring syslog to work correctly with a trial software called EventLog Analyzer. I followed the instructions here:
enable syslog
configure syslog add <ip_address> vr <virtual-router> local0
configure syslog <ip_address> vr <virtual-router> local0 severity info
enable log target syslog <ip_address>:<514> vr <virtual-router> local0
When I go to the syslog server, the only events displaying are "Setting hwclock time to system time and broadcasting time".
I thought I would be seeing alot more information. As far as the switch goes, did I enter wrong information?
Photo of David
David
  • 282 Points 250 badge 2x thumb
  • Confused
Posted 1 year ago
Photo of aloeffle
aloeffle
  • 980 Points 500 badge 2x thumb
Hello David.
here is my example config which works fine.
configure syslog add 10.0.10.57:514 vr VR-Default local0
configure log target syslog 10.0.10.57:514 vr VR-Default local0 from 10.0.10.55
enable log target syslog 10.0.10.57:514 vr VR-Default local0
I think you also  need to configure the log target syslog.
Firmware 22.2.1.5
hth
Alex
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
Here my lab X460G2 syslog settings...
configure syslog add 172.24.24.110:514 vr VR-Mgmt local0
enable log target syslog 172.24.24.110:514 vr VR-Mgmt local0
configure log target syslog 172.24.24.110:514 vr VR-Mgmt local0 filter DefaultFilter severity Info
configure log target syslog 172.24.24.110:514 vr VR-Mgmt local0 match Any
configure log target syslog 172.24.24.110:514 vr VR-Mgmt local0 format timestamp seconds date mm/dd/yyyy event-name none tag-id tag-name
The question is what kind of messages are you looking for ?
Photo of David
David
I guess I expected more that just time updates, such as a port going down because of a computer reboot. Maybe I should be patient or see if I can reboot a device connected to a switch that has my syslog configuration. I'll also edit the config just in case.
I appreciate the info!
Photo of Frank
Frank
  • 3,806 Points 3k badge 2x thumb
Hmmm - I have the same config as Ronald and I do get entries like this:
Jul 25 04:30:57 <switchname> vlan.msgs: Port 46 link down
Jul 25 04:31:00 <switchname> vlan.msgs: Port 46 link UP at speed 1 Gbps and full-duplex
I also get notices when inserting/removing SFPs.
Stupid question: is your syslog server possibly filtering? Or is it possible it's not logging "local0" to the 'right' place?
Photo of David
David
I guess I wasn't being patient as I am now seeing changes. It seems like there is a delayed response in logs but I'm not sure if that's natural or if there's a way to change how often syslogs are sent to the server.
Photo of David
David
Hello all, just a follow up...4 months later lol
What reason would I choose a different severity level? I also see debug-verbose, warning, and other options.
I want to be sure I get all the information the switch has to offer.
