SUMMIT X650-24X is modular / stackable / standalone
  • Question
  • Updated 1 year ago
  • Answered
Is SUMMIT X650-24X  is modular / stackable / standalone ?
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
Posted 1 year ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,998 Points 5k badge 2x thumb
Hi Sai,
It is standalone and can be stacked.
Here is the datasheet.
http://www.extremenetworks-ua.com/assets/files/SummitX650/DSSumX650_1442.pdf
Thanks
I was under the assumption that it has stack ports so its a stack able switch.
Then how should I differentiate stack able and standalone switch.
Thanks
SaiPrasad
Sai,
You can look in to this the other way, All Summit series switches are standalone and you need to check it can be stacked or not and for that you already have the answer.
The good thing is that all Summit series switches support stacking.
I hope this helps!
OK
On Extreme website , under switching there are categories like : Modular, Stackable , stand alone    .
How should i take it as , you are saying all are standalone.
If anyone asks what is the difference between stack able and standalone switches , there should be an answer right , i cant say all are standalone when on site i can see categorization.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,498 Points 10k badge 2x thumb
I would categorize all switches that can be stacked as stackable. The Extreme Networks product web site seems to agree mostly. That would make the X650-24x stackable.
The standalone switches listed there cannot be stacked (with the exception of the SSA, which is listed under both stackable and standalone, perhaps because of the name S-Series Standalone (SSA)).
All of the stackable switches can be used as standalone switches as well, stacking is just a possibility.
Thanks,
Erik
Makes Sense .....
Thanks
Two or more standalone switches connected/configured/managed together are called stacked switches.
Modular switches will have a Chassis,Management Modules and I/O Modules.
I hope this provides clarity.
